''Losing it''( Pop Mix ) all comments are welcome
PostPosted: Wed Aug 28, 2019 11:13 am
by mammy
44.1 khz
mp3
what do you think guys ?
https://soundcloud.com/muhammet-cev-k/losing
Re: ''Losing it''( Pop Mix ) all comments are welcome
PostPosted: Wed Aug 28, 2019 12:14 pm
by Martin Walker
Hi mammy,
Nicely written track. Do I detect elements of Katy Perry style in there, or is that just my overactive imagination? ;)
First impressions - good mix balance , with plenty of bass where it counts.
Love the opening section, although I suspect you need more of a musical hook in the first 13 seconds before your vocal comes in, so you capture the listener more quickly. Indeed, I did initially wonder if removing those first 13 seconds would help make things more powerful, so the track just starts with the vocal. Needs a little thought methinks.
However, once it gets to 0:35 and the drums/background vocals come in, I expected this pop mix to get wider and fuller, with more density. Instead, it still seems narrow. Perhaps you could try panning those 'hey' backing vocals wider and adding several more bits of ear candy during this 'bigger section, particularly if they have pan automation to add splashes of movement.
This will also give you a much greater contrast when you return to the more intimate vocal sound at 1:23. You could once again add more 'bigger mix' changes at 1:44 when the 'heys' come back in.
In a pop mix I think you need to keep ringing those changes, so you grab hold of the listener's ears and not let go ;)
Hope this helps!
PostPosted: Wed Aug 28, 2019 12:50 pm
by mammy
Thank you very much Mr. Martin .I will try your suggestions .you helped me so much. I always prefer narrow mix because very wide mixes kills the soul and tones of the song . is that true ?
PostPosted: Wed Aug 28, 2019 1:25 pm
by Dr Huge Longjohns
No.
Re: ''Losing it''( Pop Mix -Mastered version)
PostPosted: Wed Aug 28, 2019 1:29 pm
by mammy
PostPosted: Wed Aug 28, 2019 5:01 pm
by Martin Walker
Much better mix this time round - Losing It is really catchy! :clap:
The only thing I'd personally change now is to bring up the level of those 'hey hey' rhythmic backing vocals, to beef up the choruses even more.
Great work though! :thumbup:
PostPosted: Thu Aug 29, 2019 7:06 pm
by OneWorld
mammy wrote:44.1 khz
mp3
As far as engineering goes I am bobbins, production and arrangement somewhat better and to make the tune a bit more interesting I might be inclined to go 'off piste' harmonically at some point just to add a little piquancy. Where you do the drop down, might be an idea to inject a key change that lends itself to a more dynamic build/crescendo before parachuting back into the outro - if that makes sense. Good tune I reckon and lends itself to some experimentation. One thing for for sure, your vocals seem spot on
