Kick and Snare ( Do you think these drums are punchy ? )
Postby mammy » Mon Sep 02, 2019 11:47 pm
I mixed kick and snare and made parallel compression ,eq and reverb to drums .Do you think that drums are punchy ?
https://soundcloud.com/muhammet-cev-k/drum-sample
mammy
Re: Kick and Snare ( Do you think these drums are punchy ? )
Postby DC-Choppah » Tue Sep 03, 2019 4:15 am
Sounds like all close mikes. Blending in a mic from the room that captured the kit as a whole would sound great on top of this. That would also help it be punchier as a whole unit rather than isolated disconnected punches. I am not sure how to put that into words. You could use a drum buss and add parallel compression to the buss as a whole to get the sound of together punchiness after you get the mix of the drums themselves right. The room mic helps a lot with that coherent drum set sound.
DC-Choppah
Postby mammy » Tue Sep 03, 2019 10:29 am
Thank you MR. Dc.
mammy
