A compressor with 2 inputs!
Postby Hexo » Thu Oct 03, 2019 9:58 pm
I'm thinking of a compressor that has a side chain input but responds to main signal at the same time. In other words it has 2 conditions in it's code like this:
IF the signal passes the threshold THEN IF the side chain signal passes it's own threshold THEN apply gain reduction.
Do you know any compressor that works in this pattern?
Any ideas?
Best,
Ahmad.
Hexo
There are a million keys to perfection and they are buried in a million different graves.
Re: A compressor with 2 inputs!
Postby desmond » Thu Oct 03, 2019 10:24 pm
Why not just mix the two signals together and feed that into the sidechain? The compressor will then respond to the combined signal levels.
If that won't work - what's the use case that you're trying to achieve?
desmond
Postby Hugh Robjohns » Thu Oct 03, 2019 10:34 pm
I dont know of any compressors that allow the normal input and an external side-chain input to be combined; it's usually just one or the other.
But the solution is simple: just mix together the input signal and the external side-chain input signal, and feed the combination to the side-chain input -- exactly as Desmond describes.
Postby Hexo » Fri Oct 04, 2019 10:21 am
desmond wrote:Why not just mix the two signals together and feed that into the sidechain? The compressor will then respond to the combined signal levels.
I Think you gave me the proper answer. I planned to reduce my vocals on kicks, but only if the vocal is loud itself.
thank you very much!
Hugh Robjohns wrote:I dont know of any compressors that allow the normal input and an external side-chain input to be combined; it's usually just one or the other.
Well yeah! That should do it. You've always been there for us. Thanks a lot!
Hexo
Postby Hexo » Thu Dec 05, 2019 8:55 pm
Hi again!
Although I've got my answer but I found something sweet here:
https://drive.google.com/open?id=189uIUzGdwQnmbVdiOVdmsM-uBHeYfYIB
This simple Side-chain Mix knob can lead us to what we discussed earlier in Ableton!
Hexo
Postby ef37a » Thu Dec 05, 2019 10:57 pm
Isn't this just a 'ducker'?
There is probably a pedal that will do it for under a ton.
Postby Mike Caffrey » Fri Dec 06, 2019 11:38 am
DMG Compassion has a control to mix between the internal and external side chain.
Mike Caffrey
