Do I need a Gate for this?
Page 3 of 3
Re: Do I need a Gate for this?
PostPosted: Sat Nov 09, 2019 4:28 pm
by The Elf
TNGator wrote:Actually guys. Did anyone ever try taking a mounted tom sound you like and tune it down to simulate a floor tom? Its really the floor tom sound Im having problems with. The mounted tom single shots are ok by and large.
It's how we did it back in the days of Akai samplers!
Sometimes it works, sometimes not. Try it!
PostPosted: Sat Nov 09, 2019 6:48 pm
by TNGator
LOL Never venture never gain right? For years people asked Led Zep how they got that great drum sound. Did you use a sound proof room? A specially designed studio?
A sub marine? Answer: Nah....we set up the drum kit in the hall at the bottom pf the stairs and had one mic hanging from the ceiling. :headbang:
PostPosted: Sat Nov 09, 2019 9:30 pm
by CS70
The long tail is quite normal when you mic real floor toms.
It's simply a case of automate the volume on the decay with a slow fade so that it fits the rhythm of the song. A gate tends to bee too imprecise, but it's worth the time to do the individual hits.
If you then want atmosphere, simply add a huge reverb and EQ it - toms sound epic that way!
PostPosted: Sun Nov 10, 2019 12:34 am
by Eddy Deegan
TNGator wrote:... But so far, what Ive got in my downloads library all seems to have that trailing end. So if i dont find a better sound it would be good to know that I do at least have options of somehow sculpting the sound of what I have. If I can make the tom sound Im looking for I can always save it as a custom kit.
Have you considered resampling what you already have? If you were to record some hits (at the various tunings and/or velocities you use) as an audio track, then you could use fader automation/compression/gates/whatever to work on those single hits until they are sounding right, bounce/render the result as a new audio track and chop it into new 'samples' to drop in as a replacement for the originals.
Just a thought.
PostPosted: Sun Nov 10, 2019 3:10 am
by TNGator
Just a thought.
Oh i see where your going. Use the actual midi hit but freeze the track so it becomes like an audio file. Edit it and save it as tom single shot. Good idea. Worth a shot bro... ta :)
PostPosted: Sun Nov 10, 2019 5:12 am
by n o i s e f l e ur
On the subject of re-tuning drums, there's this;
https://www.waves.com/plugins/torque
PostPosted: Sun Nov 10, 2019 9:47 am
by Wonks
TNGator wrote:Oh i see where your going. Use the actual midi hit but freeze the track so it becomes like an audio file. Edit it and save it as tom single shot. Good idea. Worth a shot bro... ta :)
If you can find it on your computer, make a direct copy of the audio file of the tom hit. You can then apply whatever processing you want to cut down the decay tail, export the result, then use the resulting file in your sampler.
If you want to replace the tom sounds, then you'll need to find them anyway.
Note that if the drum sampler uses a round-robin SysNote that if the drum sampler uses a round-robin system, you'll need to edit all the samples involved.
I'd probably just draw my own volume automation envelope so I had full control of the sound, rather than use a gate or compressor.
PostPosted: Sun Nov 10, 2019 11:46 am
by CS70
Sam Spoons wrote:Yes it does but the overheads pick up a more natural amount of resonance, the close mic picks up much more and need to be controlled or it sounds unnatural. A gate can help avoid muddiness. I prefer the sound of a kit miked with overheads and kick/snare mics but when the environment or nature of the band make that impossible close mics are necessary.
Indeed! The tom mics are there to get a nice ‘thud’ and would be likely be gated on a live setting (without mics, you would not hear larger than life toms, but not much decay either).
PostPosted: Sun Nov 10, 2019 2:03 pm
by TNGator
Yeah it sounds like just using automation on the sample and saving it as a new name might be the easier option. I dont know what round robin is anyway :(
PostPosted: Sun Nov 10, 2019 2:17 pm
by Wonks
It's where you have several samples for the same note, and each gets played in turn, so it doesn't sound quite the same each time - more like a real drummer (or whatever instrument the sampler is playing). Typically three samples per MIDI note.
PostPosted: Sun Nov 10, 2019 2:50 pm
by TNGator
Wonks wrote:It's where you have several samples for the same note, and each gets played in turn, so it doesn't sound quite the same each time - more like a real drummer (or whatever instrument the sampler is playing). Typically three samples per MIDI note.
ah ..interesting. Id never seen this setting but then again....i only heard of it now so its not something I would have noticed. :thumbup:
