bit depth rendering
bit depth rendering
Postby paleface » Mon Nov 11, 2019 1:55 pm
hello
im mixing a batch of stuff ive been doing
it was recordes at 24 bit in reaper
i mixed it down to 16 bit
and decided if i wanted to change the loudness at a later date
id render the mixes at 64 bit FP in reaper
so they could be mastered at a later date if needed
most of my plugins are 64bit with a few at 32
am i causing myself any added noise by mixing up to 64 then down to 16 finally ?
paleface
Re: bit depth rendering
Postby Hugh Robjohns » Mon Nov 11, 2019 2:06 pm
In a word... yes!
Each time you work on the 16-bit tracks the DAW will process the signals at whatever internal resolution it uses (32 bit float, or 64 bit float, etc), and produce a 24-bit file ready for output... which you will then need to reduce to 16 bits. each time you do that word-length reduction you'll add more dithering, so the noise floor will be higher than it otherwise would be.
Of course, you may not notice this depending on the material involved...
The better way of working is to mix your original material within the DAW and save as a DAW project. That way you always have available the highest possible quality version if you ever need to work on it again.
If you want separate finished mix tracks to store elsewhere, they should ideally be 24 bits which will give you a good basis if any future tweaking or remastering is required ... And 16 bit versions are obviously appropriate for CD (and some domestic streaming systems).
But as a general principle, always work with the highest word-length you can, and only reduce to 16 bit as a final process of the fully finished material. And for any future reworking, always go back to the highest word-length versions available to you -- 24 bit of higher, ideally.
Postby paleface » Mon Nov 11, 2019 3:31 pm
dunno if where confused here hugh
ive rendered to 64 bit as well as 16bit
the 16bit ones are my finished versions for now ...
ive also rendered to 64bit
wich ill then use in the futre if i need to add any more loundness
the 64bit mixes will then be imported back into reaper at a later date
and rendered down to 16 bit
so the 64 bit mixes =16bit and will only go down in bit rate once to 16 bit
is noize being added on the first render from reaper (to 64bit file)
as well as from 64bit to 16 bit ?
paleface
Postby Hugh Robjohns » Mon Nov 11, 2019 3:53 pm
Sorry... struggling to understand your prose.
No noise is added when working at extended word-lengths, only when reducing the word-length to a final render.
Postby CS70 » Mon Nov 11, 2019 4:58 pm
paleface wrote:ive also rendered to 64bit
No noise is added, but it's useless - you've simply padded the samples with zeros.
It's just wasted disk space.
If the original recordings are at 24 bits, keep them and they are as good as they can get.
DAWs often compute internally at 32 or 64 bit in order to remove calculation errors when processing happens, but that happens independently on the original sample rate - you don't see that and dont need to be concerned with it.
If your mix project is at 24 bits, save the bounce at 24 bits (or as Hugh says, just keep the project) and you're set. 24 bits is the typical mix wordlength anyways for a mix, as it gets chopped down to 16 at mastering time.
You don't harm anything bouncing at 64 bit, just wasting space for no reason.
Postby paleface » Mon Nov 11, 2019 6:55 pm
so im not damaging by up rendering to 64 bit from 24bit recordings
thats good news
thank you kindly gentlemen
paleface
Postby desmond » Mon Nov 11, 2019 7:31 pm
paleface wrote:so im not damaging by up rendering to 64 bit from 24bit recordings
No damage, you're just needlessly filling your HD space with zeros and increasing the space/time required to back up/archive your files, for no practical reason that I can see. :headbang:
I'd recommend saving your original projects/recordings, and render your master mixes at 24-bit, and that's plenty good enough...
Bigger numbers aren't always better...
Postby CS70 » Mon Nov 11, 2019 7:33 pm
No, the most obvious thing that the DAW will do is simply pad each sample with 48 zeros.
When you load them in your DAW, depending on the word length and format (fixed or floating point) that it uses internally, the samples will be converted and processed at that format anyways.
Your meaningful data is still only 24 bits.
When you're in (most) DAWs, you're always operating at 32 or 64 bit (usually float), regardless of the original sample word length.
Postby James Perrett » Mon Nov 11, 2019 10:06 pm
As others have said, there is little point in storing your recordings in 64 bit format as the lower bits will have no useful information in them. If you are worried about the odd peak that goes over 0dBFS then you could use 32 bit floating point files. In normal use these will give you the same bit depth as 24 bit files but with the ability to accommodate higher (or lower) levels than fixed point files.
Postby hooty2 » Wed Nov 13, 2019 9:34 am
If my 2 cents is not pertinent to OP, please remove:
In respect of saving projects. I regularly save a 24 bit stereo mixdown to a new file (not always under reaper)..and also a copy of mixdown track back into the project as a new track.
If i delete the stereo track from 'the other place', the track in the project becomes missing/unavailable?
Why is this.
And please do move/remove if this intrudes on current discussion
hooty2
Postby n o i s e f l e ur » Thu Nov 14, 2019 12:03 am
hooty2 wrote:If my 2 cents is not pertinent to OP, please remove:
Why is this.
Probably because you're not actually importing a copy, but the original file in (from) the original location. Most, if not all DAWs will have some setting to copy files to a directory (folder) within its own control and either delete the original or leave it unmolested.
So your options are to locate and set this setting in each DAW, or make an actual copy which you can manually move to a directory of your own choosing and import from there (which is not mutually exclusive with the first option).
n o i s e f l e ur
Postby merlyn » Wed Apr 28, 2021 3:56 pm
Shaky arithmetic is probably not a good basis for making pronouncements on more advanced topics like floating point numbers and their binary representations.
Opening a 32 bit float .wav file in a hex editor :
As you can see there are no padding zeroes.
I don't know where this idea came from. The idea that 32 bit float is the same as 24 bit integer with a scaling factor. As can be seen above the exponent is being used all the time. Do you need to know this to produce bangin' beats? No.
Reasons to use a DAW's internal resolution for export
- You do not need dither.
- You don't have to worry where the master fader is or about going over.
If you were to export a 24 bit integer file you must make sure it never goes over, which could involve playing the track back repeatedly until you get the right level. Or just export at 32 or 64 bit float and don't worry about it.
merlyn
