Transgressor Plugin -Can you explain how it works ?
Page 1 of 1
PostPosted: Thu Nov 14, 2019 9:27 pm
by mammy
Hi guys. You know the transgressor plugin created by boz digital.I use it with drums and results are perfect.And I wanna know what the transgressor do to drums ? What is the main work principle ?
Re: Transgressor Plugin -Can you explain how it works ?
PostPosted: Thu Nov 14, 2019 11:38 pm
by desmond
https://www.bozdigitallabs.com/product/transgressor-2/
"The Transgressor combines a transient designer with two equalizers. No big deal you say? Any EQ plug-ins will do? Au contraire mon frère. Transgressor not only lets you equalize the attack and sustain portions of the instrument’s envelope individually (yes, you read that right; attack can be equalized differently from sustain), but it also lets you dial in the specific low, mid, and high frequencies independently on each."
"Hybrid transient designer with two 3-band equalizers with selectable slopes"
A transient processor is a system that recognises the difference between the transient (attack) portion of a sound, and the bit after it, and can adjust the characteristics of either part of the signal.
PostPosted: Fri Nov 15, 2019 9:10 am
by Zukan
I just bought it so will attack it and get back here with feedback.
PostPosted: Fri Nov 15, 2019 12:36 pm
by mammy
Thanks man .That plugin is perfect isnt it ?
