Flux Pure Compressor V3 Studio Session - Does It Have An External Sidechain?
Postby ITHertz » Tue Dec 24, 2019 2:00 pm
Hi Folks,
Does anyone know if the Flux Pure Compressor V3 Studio Session has an external sidechain?
I'm running Studio One Pro on OS X (10.14.6). The manual mentions that the AU version should have an external sidechain but I can't see it anywhere.
This isn't the case with the Flux Pure Expander V3 Studio Session which has an external sidechain clearly visible.
Cheers,
Chris
ITHertz
Re: Flux Pure Compressor V3 Studio Session - Does It Have An External Sidechain?
Postby Wonks » Tue Dec 24, 2019 3:32 pm
Can you say that again as you've apparently contradicted yourself? You may have left some words out.
"The manual mentions that the AU version should have an external sidechain but I can't see it anywhere.
This isn't the case with the Flux Pure Expander V3 Studio Session which has an external sidechain clearly visible."
Postby Martin Walker » Tue Dec 24, 2019 5:43 pm
Look more closely Wonks - the one WITH an obvious external chain is the Expander.
The one ITHertz is querying is on the other hand the Compressor in the same range.
Too many egg nogs? ;)
Postby ITHertz » Tue Dec 24, 2019 11:29 pm
Ha! Just to clarify, Pure Expander Studio Session has the external sidechain option in Studio One, but Pure Compressor doesn't (or at least I can't see where it is).
ITHertz
Postby Wonks » Fri Dec 27, 2019 1:00 pm
My fault. Not enough egg nogs.
