Basic Dynamic Delay
Basic Dynamic Delay
Postby aviorrok » Sun Dec 29, 2019 9:03 pm
I practicing mixing and I want to do a basic dynamic delay.
In this sample I just duplicate the region and filter it but I want to do this with dealy to get smoother result, how can I do it?
My sample:
https://drive.google.com/file/d/1-HWJ_N ... sp=sharing
aviorrok
Re: Basic Dynamic Delay
Postby Eddy Deegan » Mon Dec 30, 2019 2:11 am
By 'dynamic' do you mean to only apply the delay to a small portion of the sample rather than all of it?
If so, there are a few things you can do but the way I would do it would be to put a delay as an insert effect on another channel. Then, set up a send to that delay from the channel with the vocal on it. Use fader automation to raise the level of the delay only in those sections you want to hear it.
Alternatively you could insert the delay on the vocal channel and use plugin automation to control the wet/dry mix of the delay such that it can only be heard in those sections you want it to be.
Some of my works.
Postby scottfreems » Mon Dec 30, 2019 2:29 pm
Eddy Deegan wrote:By 'dynamic' do you mean to only apply the delay to a small portion of the sample rather than all of it?
+1
scottfreems
IGNITION Mixing & Mastering -- ignition@ignitionmixmaster.com
Users browsing this forum: Robby plus Bobby
