arturia lab 3 lost preset please help
Postby gilb8679 » Mon Mar 30, 2020 9:13 pm
hey guys
since i deleted my onedrive and it allso deleted my projects
i have to ask how to find my lost sounds..
i am using arturia lab 4
i searching for this sound that in this track i made...
plus
if you cant find it..do you have any suggestions on how i can get this sound?
i am using ableton 9.5 on windwos 10...
tnx in advance..
this is the track:
https://www.instagram.com/p/BzfzC54n0Oy/
gilb8679
Re: arturia lab 3 lost preset please help
Postby desmond » Mon Mar 30, 2020 10:05 pm
gilb8679 wrote:i searching for this sound that in this track i made...
plus
No one's going to remember offhand the name of which of the 1000+ presets in that plugin that you might have used. I think you just want us to search through and find the sound you used so that you don't have to look for it.
Pick some categories which seem likely candidates, and quickly flip through the sounds until you get there. It might take you a few evenings, but you can do it a bit at a time and systematically work through until you find it. It's really your job to do this, rather than expect someone else to magically solve your problem.
And next time, be a bit more careful with your projects, and your settings! Back them up, take screenshots of important settings, and generally be a bit more proactive and protective with your data... and you'll avoid these kinds of situations. :thumbup:
Good luck!
desmond
Postby gilb8679 » Mon Mar 30, 2020 10:19 pm
plus
Good luck!
tnx for the reply
i dont want you to do the job for me
but there are categories athere
like pad brass etc.
what category i should look for?...
that was the main reason for this topic
gilb8679
Postby Eddy Deegan » Mon Mar 30, 2020 10:29 pm
Some of my works.
Postby gilb8679 » Mon Mar 30, 2020 10:44 pm
yeah
same issue from the same problem..
i dont save anything on onedrive since then
gilb8679
Postby desmond » Mon Mar 30, 2020 10:46 pm
gilb8679 wrote:but there are categories athere
like pad brass etc.
Well, you can quickly rule out the ones you know it can't be - it's not a pad sound, or a brass sound, or a bass sound, or a string sound, or a drum or percussion sound... Then see what categories are left and work through those. Probably ones like Synths, Arps, Sequence are your best bet.
desmond
Postby MOF » Mon Mar 30, 2020 11:25 pm
Possibly sequenced woodwind of some sort.
MOF
Postby gilb8679 » Tue Mar 31, 2020 12:46 am
like pad brass etc.
see.. i thought its a pad...i dont really can tell the diffrent
i make music but im not familier with a lot of stuff..
every track is like a new begining...an i learn more..
im assuming i just heard it and loved it..
but i dont really know what it is likely..
tnx for your answer!!
gilb8679
Postby gilb8679 » Tue Mar 31, 2020 12:47 am
MOF wrote:Possibly sequenced woodwind of some sort.
what it means? woodwind?
i know that i heard sequqences its just doing a sample and reapit it..
doesnt it?
gilb8679
Postby gilb8679 » Tue Mar 31, 2020 12:48 am
gilb8679 wrote:
like pad brass etc.
every track is like a new begining...and i learn more..
gilb8679
Postby MOF » Tue Mar 31, 2020 5:13 pm
It’s a section of the orchestra such as clarinet, flute (they were originally made of wood) oboe etc it also includes pan pipes, didgeridoo, saxophones. The sound I heard sounded like a slightly pitched down woodwind instrument.
MOF
