Headphone Amp for Beyerdynamics DT 1990 Pro?
Postby Oscar Moos » Fri Apr 10, 2020 9:05 pm
Hello!
Probably a very basic headphone question, but I just bought a pair of DT 1990 Pro from Beyerdynamic, that I intend to use for mixing in my home studio, where I'm using a Mackie Onyx 1620i mixer as audio interface.
The DT 1990's require 250 ohms and according to the Mackie mixer's manual the headphone output is only "25Ω". I'm very confident that the headphone output will be able to give me enough volume (that channel is loooouuud), but will this affect the dynamic range of the DT1990's? Or the overall frequency response?
I've been reading on hifi forums about possible amps to use, but I want to make sure that I don't get an amp that colours the sound too much, as the idea of course is to have a flat "non-biased" playback for my mixing projects.
Any suggestions on wether to get an amp and if so any recommendations? Or should I be alright just using the Mackie mixer headphone output?
Thanks in advance!
Oscar Moos
Re: Headphone Amp for Beyerdynamics DT 1990 Pro?
Postby blinddrew » Fri Apr 10, 2020 9:47 pm
I think you'll be fine with the Mackie. Only look at an external amp if you're not happy with what you get from that.
Postby Hugh Robjohns » Fri Apr 10, 2020 9:54 pm
Oscar Moos wrote:The DT 1990's require 250 ohms and according to the Mackie mixer's manual the headphone output is only "25Ω".
They don't need 250 Ohms... They present a load of 250 Ohms... Which is an ideal load for a mains-powered headphone amp just like the one in your Mackie.
So save your money and your gear lust... Your new headphones will work perfectly with your Mackie.
Postby Oscar Moos » Mon Apr 13, 2020 5:09 pm
Thanks both of you - very helpful! I'll see how I feel about them without an amp.
Oscar Moos
Postby TabithaAudio » Fri Sep 25, 2020 9:08 pm
Hey what do I need to look for in an amplifier to be compatible with the DT 1990 PRO? I’m currently using an Apollo TWIN MKII as an interface.
TabithaAudio
Postby Kwackman » Fri Sep 25, 2020 9:50 pm
TabithaAudio wrote:Hey what do I need to look for in an amplifier to be compatible with the DT 1990 PRO? I’m currently using an Apollo TWIN MKII as an interface.
Does the headphone output on your Apollo not do the job?
Kwackman
Postby forumuser931182 » Sat Sep 26, 2020 12:04 am
Hi-Fi Forums...... Look into my eyes, look into my eyes, the eyes, the eyes, eyes, not around the eyes.
Mackie and Apollo produce extremely well designed and manufactured products at reasonable prices. They don't need their fuses replaced with audiophile ones or their capacitors replaced with black gate ones or their edges painted with a green felt pen.
forumuser931182
Postby shufflebeat » Sat Sep 26, 2020 9:27 am
forumuser931182 wrote:Hi-Fi Forums...... Look into my eyes, look into my eyes, the eyes, the eyes, eyes, not around the eyes.
Oi! Are you poking in my wallet?
shufflebeat
