Forum Topic Pruning: SOS needs your help
Page 1 of 5
PostPosted: Sat May 02, 2020 8:11 am
by Forum Admin
Hi everyone,
Our site is being negatively affected by the massive size of our database, and a vast amount of server processing and resources/caching are having to be devoted to the (phpBB) SOS Forum topics/posts. This is impacting on page-load times all across the rest of the site and our search engine's ability to perform optimally without timing out.
The SOS Forum currently has 616,472 Posts and 57,317 Topics. Regrettably, we need to reduce its Post Count by approximately one-third, circa 200,000. Post-purge, we will also need to implement phpBB's regular Post-pruning routines, which can be configured individually per sub-forum, so the post quantity does not grow massively and the oldest topics/posts will get constantly erased.
We need to action this initial pruning as soon as possible and propose to cull the oldest Topics/Posts on one or two forums at a time to reduce the massive server overhead pruning causes. We anticipate the pruning and our search engine re-indexing the remaining content taking 2 weeks to complete.
From our checks, we will need to erase every Topic (and its Posts) that has not been posted to since 01 January 2012. Achieving this will reduce the overall Post Count by the approximated 200,000 figure.
Here's where SOS needs your help...
Topics from pre-2012 that you value and see as a benefit to this community can be retained.
However, we need your help to identify them. So please look through your saved Bookmarked Topics or jump to the oldest pages of your favourite sub-forum(s) and skim through the Topic list.
When on a Topic you wish us to keep, please click on the REPORT THIS POST icon (an exclamation mark inside a circle) and type something like 'Do Not Prune' in the message box and submit it.
One of the Moderators or myself will then move that Topic and all its Posts into the existing USEFUL INFORMATION ARCHIVE (UIA) sub-forum and the Topic will become a read-only item. It will be searchable using the Forum/Main Search functions. If you then wished to 'reply' to the read-only Topic, you'd need to start a new Topic, link to the archived one, and continue discussions in the new Topic. Not ideal, but workable.
When can we start and how much time do we have?
You can start reporting valued pre-2012 Topics from today and we'll need to stop taking requests by 7pm UK time on Friday 15 May 2020.
Thanks for your understanding.
cheers,
Ian G
Re: Forum Topic Pruning: SOS needs your help
PostPosted: Sat May 02, 2020 8:51 am
by desmond
Is there any way to export a pre-pruned text dump of the forums, which can then be hosted online?
It's a shame in the age of big data that online history might be deleted, but I understand the performance and business needs to do this. But if some kind of text archive could be exported and hosted, then at least the data would be retained and be searchable just in case, rather than have a bunch of text gone forever.
Admittedly, how much value is in those posts is probably questionable, but even so...
Or is it all just a big conspiracy to stop me reaching my 10K post count..? (Again!) :lol:
PostPosted: Sat May 02, 2020 9:45 am
by Forum Admin
Hi Desmond,
We plan to take a full database backup prior to pruning and store it offline.
As to a text-dump, I've been told it's not a simple task since phpBB pulls in who posted, etc from our CMS user base, and it'll require our web team to spend expensive time to achieve this. That's time we don't have at present with all our other pressing projects and we urgently need to lighten the server load or we may find ourselves with patches of 'dark time', temporary Forum suspension, or any other undesirable scenario -- and commercially, that simply can't happen.
So the proposed solution is the optimal one.
PostPosted: Sat May 02, 2020 10:12 am
by desmond
Understandable - thanks Ian.
How are important/saved threads immune to auto-pruning in the future?
PostPosted: Sat May 02, 2020 11:08 am
The UIA forum will be the only forum excluded from the pruning regimen.
PostPosted: Sat May 02, 2020 11:25 am
by Forum Admin
I think desmond is referring to the ongoing auto-pruning of sub-forums after the initial prune has occurred.
Valid question. Each forum will have settings for its Topics and only Topics that have not been posted to in NNNN days would be candidates. And we still have to decide on each setting for the post-purge era. Unfortunately, we can't use a parameter like Days since last viewed, because there are so many search engine bots coming to the SOS Forum and crawling old (and new) posts on a daily basis.
PostPosted: Sat May 02, 2020 12:07 pm
by desmond
Sorry - yes, Ian is correct - to be more clear, let's say there was a thread from 2013 that contained content that some felt was important to be preserved. At the moment, we'd alert a mod and say "don't delete this" as part of the general prune.
But later on, auto-prune would be deleting old threads without mod intervention. So even though people had informed mods that the thread was important and shouldn't be deleted, once it fitted the auto-prune criteria in regards to date range / last posted etc (whatever that ends up being), then it will presumably be deleted automatically.
I wondered if there was going to be some mechanic or flag on threads that could be used so auto-prune wouldn't automatically delete some old but gold content...
PostPosted: Sat May 02, 2020 12:14 pm
I think the plan is to ~move~ any threads or individual posts that have been deemed valuable across into the Useful Information Archive.
As I understand it, the alternative way to prevent auto-deletion is to mark posts as 'Stickies', but as they then inherently appear at the top of the first page in each forum it wouldn't take that many saved threads before there'd be nothing new on the first page, which is clearly not a good thing!
PostPosted: Sat May 02, 2020 12:20 pm
by Arpangel
No problems here, anything to keep the forum going.
PostPosted: Sat May 02, 2020 12:21 pm
by desmond
Hugh Robjohns wrote:I think the plan is to ~move~ any threads or individual posts that have been deemed valuable across into the Useful Information Archive.
Ok, so they'd come out of their old sub-forum home to the new archive place. Would external links pointing directly to those threads continue to work, or would they break?
Hugh Robjohns wrote:As I understand it, the alternative way to prevent auto-deletion is to mark posts as 'Stickies', but as they then inherently appear at the top of the first page in each forum it wouldn't take that many saved threads before there'd be nothing new on the first page, which is clearly not a good thing!
Yes, I don't think that's a workable option, really...
PostPosted: Sat May 02, 2020 12:31 pm
by Forum Admin
desmond wrote:Ok, so they'd come out of their old sub-forum home to the new archive place. Would external links pointing directly to those threads continue to work, or would they break?
I'm pretty certain phpBB forum software creates an automatic redirect to its new home in the UIA forum, and then search engines would re-index it.
I'll do some tests over the weekend to confirm or deny this.
PostPosted: Sat May 02, 2020 12:45 pm
by Forum Admin
OK, my test is 100% conclusive...
Original URL in SOS Support Forum:
https://www.soundonsound.com/forum/view ... 30&t=69575
Topic moved to UIA forum (using Quick Mod Tools at the foot of the Topic) where the URL becomes:
As you can see, they are identical URLs. To convince myself I closed my browser (Safari), opened Chrome and pasted in the original URL. Naturally, it took me directly to the Topic and its three posts, all of which now reside in the Useful Information Archive forum.
Result. :thumbup:
PostPosted: Sat May 02, 2020 1:03 pm
by desmond
Great! :thumbup:
PostPosted: Sat May 02, 2020 2:56 pm
by ConcertinaChap
Does that mean our post counts will all be reduced and we'll all lose our Jedi status and be busted back to the ranks?
:cry:
PostPosted: Sat May 02, 2020 2:58 pm
by MOF
Everything I’ve written on this forum is pure gold and should be preserved for the nation. :lol:
Does this technical change affect my chance of ever becoming a Jedi poster?
