rogue high pitch sound in mastering process
Postby bward1998 » Sat Jun 20, 2020 11:59 pm
I have project with about 9 tracks that is at the later stage . In the Master track, a high pitched sound has appeared out of nowhere which causes a tannitis like experience for anybody who listens. Not piercing but you find your ears ringing as you listen. I have found a large spike in the Master track at about 10kHz and have eq'd it to mute. No individual track has this spike.
I am looking for anybody with experience dealing with finding such a little sob or any idea how the collection of the individual tracks would generate a sound that is not in any of the individual tracks.
In Windows 10 using Reaper 6 DAW.
Thnx
bw
bward1998
Re: rogue high pitch sound in mastering process
Postby James Perrett » Sun Jun 21, 2020 1:19 am
What processing do you have on the master track? What happens if you mute all tracks and then bring them in one at a time. Does it happen as soon as you start adding tracks or is there one track in particular that causes the issue?
Postby Hugh Robjohns » Sun Jun 21, 2020 11:01 am
Unexpected continuous HF tones like this are generally, in my experience, either the result of a howl-round due to some signal routing error, or faulty code in a dodgy plugin.
So I'd work around whatever routing you have in your final mix configuration, and check out each plugin carefully...
Postby bward1998 » Tue Jun 23, 2020 1:53 am
it turns out i had some eq’s conflicting. your suggestion caused me to look in an area i had not considered. thank you very much
enjoy life
bw
bward1998
Postby Hugh Robjohns » Tue Jun 23, 2020 10:54 am
:thumbup: :clap:
