Exported song distorts on phone speakers
Postby Pevec » Mon Jun 29, 2020 5:31 pm
Hi all,
I made a looped track for my mobile project, and it sounds okay on monitors and headphones, but when I crank phone speakers to the maximum, I can hear crackling of the rhodes piano.
I can't seem to find a way to fix this.
Heres the track: https://app.box.com/file/684917353478
Here's how it sounds on phone speakers: https://app.box.com/file/684907286282
You can hear especially on the first two chords.
I tried on other phones, but same problem.
And here's the EQ for rhodes: https://i.imgur.com/JlSwpS1.png
Pevec
Re: Exported song distorts on phone speakers
Postby Sam Inglis » Thu Jul 02, 2020 2:31 pm
Hi, and welcome to the forum!
I can't access those box.com files as it asks me to log in.
However, it's not uncommon for playback to be distorted on phones. Would you say it's more distorted on this track than with reference tracks?
Sam Inglis
Postby Pevec » Fri Jul 03, 2020 6:18 pm
Hi, here are the new links.
My mix: https://vocaroo.com/8prYCs6H5EX
How it sounds on my phone speaker: https://vocaroo.com/9vLEqvWLDub
And here is some song with rhodes piano in it, but it doesnt distort on phone: https://vocaroo.com/nDcs3unl1WB
I guess the problem is with low mids, but if I remove them completely, I'll lose that rhodes sound. Not sure how they (mix above) fixed that problem.
Pevec
Postby James Perrett » Fri Jul 03, 2020 9:28 pm
Solo piano is very good at highlighting distortion as there's nothing else going on to cover up the distortion. When you have it as part of the mix the distortion will be disguised by other elements in the mix that occupy the same frequency range as the distortion.
Postby blinddrew » Fri Jul 03, 2020 10:11 pm
Also worth trying a bit of compression in there to bring up the overall loudness and take the tops off the peaks.
Postby Pevec » Sat Jul 04, 2020 3:21 pm
James Perrett wrote:Solo piano is very good at highlighting distortion as there's nothing else going on to cover up the distortion. When you have it as part of the mix the distortion will be disguised by other elements in the mix that occupy the same frequency range as the distortion.
Unfortunately, same thing is happening in the whole mix as well.
The only workaround I have found is to cut lows and low mids from rhodes VST.
Pevec
Postby CS70 » Sat Jul 04, 2020 7:02 pm
I guess you probably should, then? :D
Sounds like a good case for a multiband compressor tough.
Postby Pevec » Sat Jul 04, 2020 9:13 pm
I lose that sound when I do that, but if it works, I have no other choice :D
Gotta check some tutorials on multiband compressor, since I'm not a pro :D
Pevec
Postby CS70 » Sat Jul 04, 2020 9:44 pm
A MBC allows you to compress only a certain band and only when the level of that band is over a certain threshold (and it will do it with attack and release of your choice etc, like a regular compressor)
It could allow you to tame the low end when it is troubling the phone speaker while leaving it untouched while it doesn’t.
But hard to say what’s what without working the entire mix and looking at the sources.
