Final Cut to Logic Workflow????????
Postby Eargasm95 » Tue Aug 04, 2020 1:13 pm
Hey guys hope everything is well!
I'm trying to Export/import a project from Final cut pro X version 10.4.8 to Logic Pro X 10.4.8
I understand that the way to this is by organising the audio into roles and then creating a XML file but the problem I am having is that a lot of the audio seems to be missing when it arrives in Logic Pro X, I looked in all the drop downs of the tracks and still nothing!
I also tried importing it to DaVinci Resolve and then to final cut but the issue is somewhat worse as the audio falls out of order and is a complete mess!
Can somebody please help me?
Eargasm95
Re: Final Cut to Logic Workflow????????
Postby desmond » Tue Aug 04, 2020 1:31 pm
Find the first item that is missing when exported, and check that item in FCP. What audio role is it, and where should it be going?
If you examine the items that don't show up, compared to the ones that do, you might get an idea of what's causing the issue.
There's probably youtube videos walking you through the process, have you tried looking there? Or on FCP forums, as this is really a FCP issue (how to handle audio in your FCP projects).
desmond
