Help with my EQ Target in diy Master
Re: Help with my EQ Target in diy Master
Postby RichardT » Fri Aug 14, 2020 1:56 pm
I’ve found Mike Senior’s book ‘Mixing Secrets for the Small Studio’ to be a great help. It’s a really clear step by step guide.
If your room really is bad, it will be very hard to get a good mix. Installing some treatment will really help. Can you do the majority of your work on phones and then audition your mixes in a better environment for fine adjustments (this is what I do)?
RichardT
Postby blinddrew » Fri Aug 14, 2020 2:59 pm
Mixmoister53 wrote:Sigh, I'm so over this track.
If it's any consolation, I'm pretty sure we've all been at this stage with one track or another. It's all part of the learning process. :)
