identify the effect
identify the effect
Postby zosososozo » Fri Aug 14, 2020 12:28 pm
really enjoy the sound of this track, there's a certain effect in a lot of his sounds and music that I'm trying to identify
https://www.youtube.com/watch?v=czl9kKwc-z0
the vocal in the beginning has it, the synth in the higher notes from 0:30 min also has it.
It sounds quite hollow and slightly metallic, and the sound feels less direct. But sits really interesting. Maybe someone can help out. Is it a certain reverb or a certain harmonizer ?
zosososozo
Re: identify the effect
Postby desmond » Fri Aug 14, 2020 12:43 pm
It sounds to me like various stereo delay treatments, ranging from flanging through to chorusing - mostly small delay times, offset per channel to give a widening effect.
Pick you favourite delay plugin and start experimenting with small delay times and see how far that gets you.
desmond
Postby Tim Gillett » Fri Aug 14, 2020 2:44 pm
As you say it's also hollow. A lot of the bass has been removed from the vocal.
Tim Gillett
Postby Hugh Robjohns » Fri Aug 14, 2020 8:39 pm
Short delay with inverted polarity will knock the low-end out like that.
