'Home cinema' with active monitors
Re: 'Home cinema' with active monitors
Postby Hugh Robjohns » Tue Jun 08, 2021 12:09 pm
ef37a wrote:...can find nothing in the way of a pre-amp with balanced outputs.
Only the high-end hi-fi people and pro gear will offer balanced outputs. But the Result 6s will be quite happy with unbalanced inputs in a domestic situation.
Modern amps all seem to be equipped with Blue Teeth but no phono RIAA inputs and I would like to integrate my Rega Planar TT into the setup.
There are plenty of affordable stand-alone phono preamps that you can use to bridge the gap between phono pickup and line input. The Rega Fono MM for example (£200).
Postby ef37a » Tue Jun 08, 2021 1:09 pm
Stuff that! I am not paying 200 sovs for a few transistors and caps to transcribe my old LP collection! I do not intend to ever buy new vinyl.
Re the balanced lines, The run from amp to speakers could well be over 5mtr and avoiding mains wiring quite tricky so a few quid for the modules is no problem.
Postby Wonks » Tue Jun 08, 2021 3:55 pm
ef37a wrote:*I have set the chest pump on the PMC Result 6 but the flexible friend has has a serious bashing this year so I might have to lower my expectations. Has anyone heard the Sixes alongside anything nearly as good but half the price? .
A single PMC Result 6 and listen in mono? ;)
Postby ef37a » Wed Jun 09, 2021 12:13 pm
Leave it out! I get almost nothing past 2kHz these days but can still enjoy stereo!
