What do you use on the master fader?
Postby dennisgamalej » Thu Oct 01, 2020 9:54 pm
Hey guys,
I have a question so i have an inspiration. What plugins do you use on the master fader?
Thank you! :)
dennisgamalej
Re: What do you use on the master fader?
Postby RichardT » Thu Oct 01, 2020 9:59 pm
Magic Death Eye Stereo Compressor
Fabfilter pro-q3
Fabfilter pro-l2
Sonarworks reference 4
But lots of other plug-ins would be as good. Or better.
RichardT
Postby blinddrew » Thu Oct 01, 2020 10:01 pm
It will depend on the piece, but generally there'll be an eq with a lo-cut just to clean up any stray LF rumble that might have made it through.
Normally a compressor doing a bit of glue work, i'm currently using one of the free Klanghelm ones in this role unless i find it needs something else.
A loudness meter (courtesy of Melda).
And that's my starting point generally.
Postby shufflebeat » Fri Oct 02, 2020 1:30 am
I've been playing with, and coincidentally recently discussing, Airwindows Console6. It's an intriguing bit of code that is very difficult for a technidiot like myself to describe but should be explored.
shufflebeat
Postby resistorman » Fri Oct 02, 2020 2:57 am
Usually EIOS EQ, PSP Master Comp and/ or Stilwell Bombardier, Gullfoss, PSP Xenon if it’s a one-off or a rough. If the mix is part of a compilation or album project, I’ll save all that for later. For some reason, I favor channel and sub processing in studio and master processing for live sound.
resistorman
Postby awjoe » Fri Oct 02, 2020 3:18 am
Ozone. It's got everything I want on a master bus, all in one plugin.
awjoe
She even asked me if I wanted a sausage roll. That normally is a good sign.
Postby Arpangel » Fri Oct 02, 2020 7:28 am
ReaComp ReaEQ and Valhalla Vintage Verb, I’m not a big fan of plugs, let alone paying decent money for them, fifty quid for Vintage Verb made me wince a bit.
Postby Alba » Fri Oct 02, 2020 8:27 am
A piece of scotch tape.
Alba
Postby ore_terra » Fri Oct 02, 2020 8:55 am
Arpangel wrote:ReaComp ReaEQ and Valhalla Vintage Verb, I’m not a big fan of plugs, let alone paying decent money for them, fifty quid for Vintage Verb made me wince a bit.
what use do you give to the reverb as insert in the master bus??
ore_terra
Postby Mike Stranks » Fri Oct 02, 2020 9:04 am
Not really relevant to most of you, but as a 'radio' man mixing both commercial (licenced) music and voice I have a different approach.
Music tracks have nothing done to them - apart from normalising to -1dB.
Individual voice tracks can have all sorts of stuff depending on the source quality. They will have a selection of: Hi-pass, intelligent NR, de-ess, de-mouth-click, and gentle voice-centred EQ. On occasion I use time stretching/compression which is independent of pitch. Then normalised to -1dB.
The master-fader usually just has a Broadcast Processor set to a very mild setting and also with level set to -1dB.
Postby Luke W » Fri Oct 02, 2020 9:44 am
As little as possible for me usually! The only thing I use on almost everything is FabFilter Pro-L2, mainly for the loudness metering.
Luke W
Postby Arpangel » Fri Oct 02, 2020 10:28 am
I often use it for giving a wash to a whole mix, or to a piece that may end up as an element of a bigger mix. Sometimes a mix that I intended to work as a finished piece isn’t successful, so I’ll store it in my "compost" folder until I can find a use for it as part of something else, something bigger, the reverb is often just a sound shaper, that makes a particular texture, or blurs things that didn’t work so they just become one one big mass, and you don’t hear the faults.
Postby James Perrett » Fri Oct 02, 2020 2:07 pm
Only a LUFS metering plug-in and a limiter that is bypassed (but available at the click of a mouse if needed). Everything else depends on the material I'm working on.
Postby Martin Walker » Fri Oct 02, 2020 2:28 pm
mda TestTone (only enabled with -18dB pink noise during initial pink noise mixing setup)
TDR Slick EQ M (for small, final EQ tweaks)
TDR Kotelnikov GE (for typically 1 to 2dB gentle overall compression, to 'glue' everything together)
