Passive Monitors / Amp under $2k
Re: Passive Monitors / Amp under $2k
Postby RichardT » Sun Oct 18, 2020 9:49 am
The difference between $200 and $2000 monitors is absolutely vast! Accuracy of frequency response is only a small part of the picture. Better monitors are clearer, more subtle and more dynamic.
RichardT
Postby Hugh Robjohns » Sun Oct 18, 2020 10:27 am
bluedot wrote:...if the intention of this calibration is to make it flat, why will we continue to use high end monitors? If it remains flat through calibration - would one hear the difference between a $200 monitor and a $900 monitor?
Yes, you'd hear the difference.
The frequency/amplitude response is only one aspect of the speaker/room/listener chain, as Drew has already explained.
Some -- by certainly not all -- speaker correction system also control the phase response across the frequency range (which can be pretty wacky in conventional speaker designs).
But they can't do anything about amp and driver distortion products. They can't do anything for time-domain smearing through cabinet and driver resonances. They can't do anything for the varying directivity of the drivers (the speaker's polar response).
A lot of things get a lot better if you are able to throw more money into the design of the speaker and the quality of the components employed.
Of course, the law of diminishing returns applies. The step up from a $250 speaker to a $2,500 one is very obvious... but to get the same level of improvement again you could easily have to spend $25,000 -- and many pro studios and mastering facilities do!
Postby ef37a » Sun Oct 18, 2020 3:08 pm
" The step up from a $250 speaker to a $2,500 one is very obvious.."
Ooo, I AM glad you said that Hugh!
Postby bluedot » Sun Oct 18, 2020 3:32 pm
Hugh Robjohns wrote:Of course, the law of diminishing returns applies. The step up from a $250 speaker to a $2,500 one is very obvious... but to get the same level of improvement again you could easily have to spend $25,000 -- and many pro studios and mastering facilities do!
Thanks all. That is the education I had hoped for.
bluedot
