How can I use delay like this?
Postby aviorrok » Thu Oct 22, 2020 12:32 am
Hi,
How can I get delay feedback effect like the "Pro" mixers
Here is an example of what I mean
The delay on the "oh" is feedback only the "h" how can I do it?
https://youtu.be/SXiSVQZLje8?t=12
Thanks!
aviorrok
Re: How can I use delay like this?
Postby MOF » Thu Oct 22, 2020 2:12 am
What equipment are you using? If you have a DAW then you need to draw in automated auxiliary sends to the delay on the vocal that sings ‘Oh’.
MOF
Postby The Elf » Thu Oct 22, 2020 8:41 am
It's automation, or (my preferred method) a second duplicate track that feeds the delay and cut/shaped (sometimes also using automation) to add the delay at the appropriate moments. I like the second track method for vocals as I find it helps me 'see' what I'm doing better than automation lines.
Postby Hugh Robjohns » Thu Oct 22, 2020 10:29 am
^ Wot 'ee zed!
I also prefer the duplicate track and edit method -- it's not only easier to see on the timeline, but it's the way I learned to do it back in the days of analogue multitracks!
Postby Zukan » Thu Oct 22, 2020 12:24 pm
You can create delay throws without having to use a delay effect. We use this technique with both Hip Hop and EDM productions.
Zukan
Postby Martin Walker » Thu Oct 22, 2020 6:20 pm
The Elf wrote:It's automation, or (my preferred method) a second duplicate track that feeds the delay and cut/shaped (sometimes also using automation) to add the delay at the appropriate moments. I like the second track method for vocals as I find it helps me 'see' what I'm doing better than automation lines.
What a great idea!
Only today I've been adding some spot echos to a track with several superimposed automation lines controlling echo level and feedback, and it is indeed much harder to take in visually.
So I shall be co-opting this 'dupe echo track' technique in future :thumbup:
Postby CS70 » Fri Oct 23, 2020 7:48 am
What a great idea!
With Cakewalk, you can get the DAW to draw the waveform on a bus channel. Guess you can on other DAWs as well?
I usually send to the "effect delay" bus, draw automation there and turn on the waveform drawing, so that after every pass I get to see exactly where I'm actually generating signal or not, and I can fine tune the automation on the bus.
Postby aviorrok » Tue Oct 27, 2020 12:26 am
Cool thanks!
aviorrok
