Ground loop issue, snipped cable screen connections to pin 1 now monitor pops loud when turned off
Postby zakduff » Sun Oct 25, 2020 2:31 pm
I had a ground loop issue so i found a few posts on here which instructed the following:
“At the speaker ends of both balanced cables, open the connectors and snip out the cable screen connections (to the sleeve or pin 1). “
I have done this and it has resolved my issue and no longer have a buzzing sound however when I turn off my studio monitor it pops loudly. Obviously I’m turning my (powered) studio monitors off first and my volume is down on my audio interface but it still pops really loudly.
Any advice will be appreciated
zakduff
Re: Ground loop issue, snipped cable screen connections to pin 1 now monitor pops loud when turned off
Postby zakduff » Sun Oct 25, 2020 2:48 pm
Update:
Not sure what was causing it but it’s not happening anymore
I did have another XLR cable plugged in to my other monitor which I hadn’t altered yet.
I also did turn it off only about 10 seconds after powering it on.
Guessing it was one of these two factors that was causing it to pop?
But hey ho, its OK now :)
zakduff
Postby Hugh Robjohns » Sun Oct 25, 2020 4:16 pm
Postby Martin Walker » Mon Oct 26, 2020 4:27 pm
Hi zakduff, and welcome to the SOS Forums! 8-)
Glad to hear you've solved your problem, but if anyone else wants more info on possible XLR pin 1 ground loop problems, have a read of my Q&A here:
https://www.soundonsound.com/sound-advi ... ound-loops
Postby zakduff » Sun Nov 22, 2020 4:22 pm
Hugh Robjohns wrote::thumbup:
Hi Hugh,
Late update but when i’ve just turned my studio monitor on its caused a loud pop similar to that time i turned it off.
It was the same monitor (right) as last time, any ideas? :)
zakduff
Postby Hugh Robjohns » Sun Nov 22, 2020 5:32 pm
Could be myriad reasons. I wouldn't be concerned u less it becomes a regular thing.
Postby zakduff » Wed Nov 25, 2020 6:08 pm
Hi Hugh,
Admittedly I hadn’t turned my monitors on since uploading this post
I have just filmed turning them on and right monitor popped again and then the left monitor started buzzing
https://streamable.com/wtcq9a
Please see the above link (sorry if i am not suppose to share video links)
zakduff
Postby zakduff » Thu Nov 26, 2020 6:08 pm
Hugh Robjohns wrote:Could be myriad reasons. I wouldn't be concerned u less it becomes a regular thing.
zakduff
Postby James Perrett » Thu Nov 26, 2020 7:37 pm
Have you checked that the monitors are actually grounded? Do they have a 3 core power cable? Has the power wiring in your studio been checked recently?
Postby zakduff » Thu Nov 26, 2020 8:44 pm
James Perrett wrote:Have you checked that the monitors are actually grounded? Do they have a 3 core power cable? Has the power wiring in your studio been checked recently?
Yes, yes and no :D
What checks would that be specifically?
zakduff
Postby James Perrett » Thu Nov 26, 2020 9:15 pm
If you are in the UK I'd suggest one of the socket testers with three lights on them like the one at
https://www.toolstation.com/socket-tester/p82826
Postby zakduff » Thu Nov 26, 2020 11:31 pm
Yes i am in UK, I’ll order one and see :) Thanks James
zakduff
