Ground loop issue, snipped cable screen connections to pin 1 now monitor pops loud when turned off
Postby zakduff » Sun Oct 25, 2020 2:31 pm
I had a ground loop issue so i found a few posts on here which instructed the following:
“At the speaker ends of both balanced cables, open the connectors and snip out the cable screen connections (to the sleeve or pin 1). “
I have done this and it has resolved my issue and no longer have a buzzing sound however when I turn off my studio monitor it pops loudly. Obviously I’m turning my (powered) studio monitors off first and my volume is down on my audio interface but it still pops really loudly.
Any advice will be appreciated
zakduff
Re: Ground loop issue, snipped cable screen connections to pin 1 now monitor pops loud when turned off
Postby zakduff » Sun Oct 25, 2020 2:48 pm
Update:
Not sure what was causing it but it’s not happening anymore
I did have another XLR cable plugged in to my other monitor which I hadn’t altered yet.
I also did turn it off only about 10 seconds after powering it on.
Guessing it was one of these two factors that was causing it to pop?
But hey ho, its OK now :)
zakduff
Postby Hugh Robjohns » Sun Oct 25, 2020 4:16 pm
Postby Martin Walker » Mon Oct 26, 2020 4:27 pm
Hi zakduff, and welcome to the SOS Forums! 8-)
Glad to hear you've solved your problem, but if anyone else wants more info on possible XLR pin 1 ground loop problems, have a read of my Q&A here:
https://www.soundonsound.com/sound-advi ... ound-loops
Postby zakduff » Sun Nov 22, 2020 4:22 pm
Hugh Robjohns wrote::thumbup:
Hi Hugh,
Late update but when i’ve just turned my studio monitor on its caused a loud pop similar to that time i turned it off.
It was the same monitor (right) as last time, any ideas? :)
zakduff
Postby Hugh Robjohns » Sun Nov 22, 2020 5:32 pm
Could be myriad reasons. I wouldn't be concerned u less it becomes a regular thing.
