Hi all - first post on here (but long-time SOS reader).
I used to have a small home studio when I was gigging lots, but life got in the way of music. Now getting back in to mixing etc; amazing where technology has got us compared to 18 years ago when I was last playing around!
I've been re-teaching my mixing techniques, and would welcome some critique on a mix I've just done. I found the multitracks to a great track on the Cambridge-MT site, and had a crack...
This is the original reference mix: https://www.youtube.com/watch?v=g87dpRh8X-A
And this is my attempt: https://soundcloud.com/user-885467395/c ... 7FMhhqd1mV
Really appreciate any comment. I'm pretty happy with it, but I'm a bit biased... My one issue at the moment is that I'm mixing primarily on headphones (but a pair that I understand well), checking on a few systems here and there. Need to get some decent monitors sorted next!
Mix critique
• Page 1 of 1
Re: Mix critique
Welcome to the forum.
You've obviously kept some things similar to the reference but others not. eg: I notice the main vocal sounds quite different in tone. Did you have a problem with the vocal in the ref mix?
- Tim Gillett
- Frequent Poster (Level2)
Re: Mix critique
Hi Tim. Yes I wasn't a fan of its harshness - the printed stem has some distortion on it which made it quite 'telephony', especially when the vocalist is pushing it a bit. Attacked it with some dynamic EQ to tame the bits I didn't like when it was getting rougher. I wanted a bit of a smoother, rounded sound. I also thought the mids in the reference were a bit crowded at times, to which the vocal was contributing a bit.
- Guest
Re: Mix critique
Nice to have you here! :thumbup:
That's sounding pretty good (I didn't listen to the reference), but the vocal needs de-essing and generally making sound 'expensive'.
Don't worry about mixing in headphones; despite what some may say it is perfectly possible to create commercially acceptable mixes in headphones, providing you fully understand what you are hearing - and I'm living proof! ;) :D
The Elf - Jedi Poster
Re: Mix critique
The Elf wrote:Nice to have you here! :thumbup:
Thanks for the comments - I was worried about over-doing the de-essing on the vocal; there is de-essing on there already, but I suspect not enough. What would you look at doing with the vocal to add that expensive fairy dust?
- Guest
Re: Mix critique
That's quite a difficult task to do over a forum, especially without hearing the source material, but I would consider...J_J wrote:What would you look at doing with the vocal to add that expensive fairy dust?
De-essing, de-midding, HF boost, compression/parallel compression, automation, FX automation, 'epic' delay/reverb.
Re: Mix critique
You can't beat a nice epic delay/reverb! :lol:
Hugh Robjohns - Moderator
Re: Mix critique
The Elf wrote:That's quite a difficult task to do over a forum, especially without hearing the source material, but I would consider...J_J wrote:What would you look at doing with the vocal to add that expensive fairy dust?
Thanks for this - so all these ingredients are there (less parallel compression), but clearly not quite weighed out correctly. I'll have another go at them; thank you for the ideas.
- Guest
Re: Mix critique
:lol:Hugh Robjohns wrote:You can't beat a nice epic delay/reverb! :lol:
Think 'Alpine'! ;)
Re: Mix critique
The Elf wrote::lol:Hugh Robjohns wrote:You can't beat a nice epic delay/reverb! :lol:
Think 'Alpine'! ;)
Surely 'Alpine' refers to the slopes used in EQ roll-off settings? :tongue:
Martin Walker - Moderator
Re: Mix critique
Whatever it is it's gotta be cool...
Sam Spoons - Jedi Poster
Re: Mix critique
Martin Walker wrote:Surely 'Alpine' refers to the slopes used in EQ roll-off settings? :tongue:
If it's not +9db or more I'm not interested :bouncy:
- Guest
Re: Mix critique
Blimey Hugh, I actually agree :D
A nice expensive valve compressor with huge meters and knobs would also work well, but only if you listed it in the credits, and preferably, included a picture, that always makes a massive difference to how things actually "sound"
:D :D :D
Arpangel - Jedi Poster
