A new (to me) trick for dealing with excessive bleeding.
Postby Moroccomoose » Sun Nov 22, 2020 9:53 pm
So this week I have been playing with a new trick I learned to help reduce....or in some cases almost eliminate...bleed.
I used it on an old recording of a rehearsal session from a band I was in a long time ago. Every track had loads of bleed making it very tricky to have any kind of control over the mix.
The technique I used was to take a track with bleed problem, duplicate it and phase invert. Send both tracks to a bus and of course they null to silence.
Then put a compressor on the phase inverted track with fast attack and high ratio, then tweak the threshold to optimise bleed reduction against pumping.
It works brilliantly on drums, much more natural than using a gate. I even managed to pull a vocal out of the mud a little bit using this technique.
Credit to Warren Huart for describing the technique on his channel.
Stu.
Moroccomoose
Re: A new (to me) trick for dealing with excessive bleeding.
Postby CS70 » Sun Nov 22, 2020 9:59 pm
Cool one! Never been a fan of gated kicks and snares myself.
The more I mix drums, the more I tend to leave bleed in the closed mics as well, often using some EQ to shape the sound.
Postby RichardT » Sun Nov 22, 2020 10:00 pm
I thought your post was going to be about something completely different.
Though in its own right it’s definitely interesting.
RichardT
Postby The Elf » Sun Nov 22, 2020 10:44 pm
I've used a version of this trick to eliminate guitar amp buzz - it can work well.
Postby Hugh Robjohns » Mon Nov 23, 2020 12:59 am
It's basically parallel compression (aka London compression or New York compression) with a polarity inverting twist!
Low level signals -- meaning the background spill -- wont exceed the compression threshold so wont activate the compressor. Consequently the two signal paths are identical and everything cancels out. Spill removed.
High level signals -- the wanted signals -- do activate the compressor, so get reduced in level (a lot thanks to the high ratio and hopefully low threshold). Now the two signal paths are very different, and thus cannot cancel out or reduce the wanted sound to any significant degree.
Obviously, Setting the right threshold level is critical to the effectiveness, as well as the attack and release times. And you'll want a fast acting (FET or VCA) compressor with a very wide attenuation range.
Postby Martin Walker » Mon Nov 23, 2020 2:32 am
There I was about to suggest running it under the cold tap, slapping on some Savlon, and then getting on a plaster before it starts bleeding again.
And instead I learned a new audio technique that I intend to try out - thanks Stu! :thumbup:
Postby Tim Gillett » Mon Nov 23, 2020 4:22 am
Isnt it just gating or downwards expansion by another route? What advantages does it have over those? Can we hear some AB audio examples?
Important also to compare like with like, ie: use exactly the same equivalent attack/release/ratio settings. Then we are comparing only the two methods.
Tim Gillett
Postby adrian_k » Mon Nov 23, 2020 7:43 am
I think I vaguely remember a Mike Senior SOS article from years ago on this, and some other more complex versions, I’ll see if I can find it.
adrian_k
getting better all the time..
Postby The Elf » Mon Nov 23, 2020 10:31 am
Tim Gillett wrote:Isnt it just gating or downwards expansion by another route? What advantages does it have over those? Can we hear some AB audio examples?
It's slightly more benign, in that any lag in the response of the inverted signal leaves the target audio unaffected.
But yes, it's not anything new or miraculous.
