Hiss on my bus
I feel slightly foolish asking but....there's is a noticeable hiss on my master bus when I insert my analogue hardware that was not there before and I'm wondering what's causing it.
I mix through a Focusrite Control 2802 and the Mix Insert is patched into an external jack to jack patchbay. On the patchbay I have available a TK Audio BC1 compressor, a Manley Elop+ compressor and a Thermionic Swift EQ. I usually patch in the BC1 to the Elop to the Swift, bypassing the units that are not needed. A small amount of hiss is to be expected but since Monday it has become quite noticeable when I crank up my monitor pot on the desk (around 92dBSPL).
Two things have happened that might be to blame. I have replaced my isolated patch bays (I had Signex QPP48 Patchbays) with two Signex CPJ48 full normalised patch bays; and I've upgraded the cabling to and from the desk Mix Insert points.
To my ears the new patch bays have made everything that runs through them sharper - might it be that the hiss I'm now hearing was always there and now I can hear it better? Or might the fact that the patch bays are full normalised be creating something in the signal chain? Or might I be barking up the wrong tree on both counts?
Any and all advice welcome.
Thanks,
Mat
Thanks,
Mat
