Do the pros still record / mix in 24-44.1?
Postby TheLegit » Thu Dec 17, 2020 8:25 pm
Just wondering if things have moved on and if people are now recording/ mixing in say 24-48khz or even 96khz before rendering to 16 bit 44.1 or 24 bit 44.1.
TheLegit
Re: Do the pros still record / mix in 24-44.1?
Postby desmond » Thu Dec 17, 2020 8:28 pm
Yes, 24/44 or 48 is the general recommended standard for most people and has been for years now.
24-bit has *significant* advantages. As for sample rates, that's a bit more "user's choice", you don't generally *need* much more than 48 but there are some benefits in some cases of 96 and if you need it, you generally *know* you need it.
I tend to stick to 44, but 48 has a slight benefit but it's not a huge deal imo, unless you're doing stuff for video in which case 48 makes sense.
Postby Hugh Robjohns » Thu Dec 17, 2020 9:29 pm
I'm coming across a lot more recorded at 96/24 these days, driven primarily by the high-quality download market.
Postby James Perrett » Thu Dec 17, 2020 10:52 pm
I'm doing more at 24/96 these days but still do a fair bit of stuff at 24/44.1 for eventual CD release.
Postby tomas_man » Thu Dec 17, 2020 11:04 pm
Also more and more studios rely on network systèmes such as Dante or AVB which tend to work in 48/96.
tomas_man
Postby Martin Walker » Thu Dec 17, 2020 11:10 pm
Like desmond, I'm still on 24/44 for recording, and I dither to 16/44 for release.
As Hugh says there is significantly more recorded material available for the high quality download market at 24/96, but in a playback environment I really don't think that any more than a tiny fraction of listeners are going to notice the difference from 16/44.
I also resent being asked more money for 24/44 than for 16/44 (some labels offer both bit-depths, but I defy anyone to hear any practical difference in dynamic range).
Postby ken long » Fri Dec 18, 2020 8:38 am
24/96 at work
24/44 at home
ken long
I'm All Ears.
Postby Arpangel » Fri Dec 18, 2020 8:57 am
I record in 16/44.1 mainly, as I like my music to end up on CD.
Postby ef37a » Fri Dec 18, 2020 9:16 am
Arpangel wrote:I record in 16/44.1 mainly, as I like my music to end up on CD.
IMHO that is just making life harder work! I use Samplitude and do everything* at 24 bits and export samples at 16/44.1. Not that I burn CD very often but We Transfer stuff to son.
*I use Audacity at 16/44 to 'grab' stuff off the net, no point in using better.
Postby Arpangel » Fri Dec 18, 2020 9:34 am
Sometimes I don’t even know what rates I’m using, until I look at the project info in the tool bar. It doesn’t seem to matter anyway, I can’t hear any difference at my age.
Postby The Elf » Fri Dec 18, 2020 9:40 am
24/44.1 here - and export to 16/44.1. Any 'benefits' to higher rates are of questionable value, but 24 bits gives me room for manouvre during editing/processing.
Postby ef37a » Fri Dec 18, 2020 9:42 am
Have you tried taking more water with it?
Postby Eddy Deegan » Fri Dec 18, 2020 10:24 am
24-bit/48kHz here, but only because my desk doesn't support 44.1.
Disclaimer: Serious though I take my shizzle, I'm not a pro.
Postby Arpangel » Fri Dec 18, 2020 10:31 am
I’m a Gin man Dave, maybe I need more tonic....
:crazy: :)
Postby Hugh Robjohns » Fri Dec 18, 2020 11:10 am
ef37a wrote:IMHO that is just making life harder work!
It is... but don't go there... life is too short :lol:
For what it's worth, everything I do by way of real acoustic recorded music is at 96/24 and then I convert the finished, mixed, mastered product as needed. Other projects --- voice overs, podcasts etc -- will be at 48 or 44.1 as necessary -- but always 24 bit.
