What Key do you put your vocals in when using Auto Tune?
Postby Tjbenz » Thu Jan 07, 2021 5:33 am
Curious what Key you guys use when using auto tune for vocals. I know the "classic T Pain" style is a C Major but I have been using D-Major on my vocals and it seems to sound better. Curious what you guys are using. Attached is my vocals with D-Major for reference.
https://youtu.be/LQLKdus7woA
Tjbenz
Re: What Key do you put your vocals in when using Auto Tune?
Postby Aled Hughes » Thu Jan 07, 2021 8:59 am
Sorry if I’m missing something here, but surely you set it to the key of the song?
Aled Hughes
www.stiwdiosain.cymru
Postby Luke W » Thu Jan 07, 2021 9:04 am
Ramirez wrote:Sorry if I’m missing something here, but surely you set it to the key of the song?
Also a little confused and thinking the same thing.
Luke W
Postby CS70 » Thu Jan 07, 2021 9:11 am
I just read an article about this T-Pain at https://www.washingtonpost.com/news/art ... ink-he-is/ and I felt like I had just arrived from Mars.
There is apparently a mega-hit called “Fancy” by a guy called Iggy Azalea and I have never heard of either.
Jesus.
For the OP: I have no idea. I suppose you put it in whatever key sounds good to you. That, has not changed in music since we went past Gregorian chants.
Postby blinddrew » Thu Jan 07, 2021 11:57 am
Hmm. Add me to the 'why would you not tune to the key of the song?' group... :?:
[EDIT] Just listened to your track, which is in Am I think, so I think part of what might be happening here is around the use of autotune as an effect rather than as a corrective process (which might be how a few of us think of it).
By choosing an autotune key that's not the key of the song you're going to get a very obvious and pronounced slurring of the note - highlighting the effect. If you're chosen to use C over an Am track that's going to be much less apparent as Am is the relative minor of C.
Postby Aled Hughes » Thu Jan 07, 2021 12:15 pm
blinddrew wrote:Hmm. Add me to the 'why would you not tune to the key of the song?' group... :?:
A very good point!
Aled Hughes
Postby Martin Walker » Thu Jan 07, 2021 3:55 pm
CS70 wrote:There is apparently a mega-hit called “Fancy” by a guy called Iggy Azalea and I have never heard of either.
Er, Iggy Azalea is a female rapper :beamup:
Postby blinddrew » Thu Jan 07, 2021 4:48 pm
I was going to let that pass, I thought CS70 was having a tough enough day already... ;)
Postby Music Wolf » Thu Jan 07, 2021 4:51 pm
He did say that he hadn't heard of them :bouncy:
Music Wolf
Postby MOF » Thu Jan 07, 2021 6:27 pm
Autotune can make it very difficult to ascertain what gender the vocalist is. :lol:
MOF
Postby shufflebeat » Thu Jan 07, 2021 8:39 pm
Should I be rethinking my assumptions about Iggy Pop as well now?
This is so confusing.
I'm not an autotune connoisseur but the way I understand it from my explorations is that choosing a key (in it's most basic form) merely limits the options as regards the number of notes that the effect will pull towards.
If this is the case and your performance isn't too far off the mark then "chromatic" should suffice for most applications.
...or am I stuck in the early 2000's?
shufflebeat
Postby BJG145 » Thu Jan 07, 2021 9:12 pm
Tjbenz wrote:Curious what Key you guys use when using auto tune for vocals. I know the "classic T Pain" style is a C Major but I have been using D-Major on my vocals and it seems to sound better. Curious what you guys are using. Attached is my vocals with D-Major for reference.
The track moves between two chords based on Em and F. It starts on Em.
The first note you sing is F#. That note appears in the scale for Em, and in the scale for D. So if you set up Autotune with either of those, it will aim to pull that note to the correct pitch.
It doesn't appear in the scale of C however. So if you set up Autotune with C, it would try to pull that note either flat to F, or sharp to G, depending which it thought was closest. Neither would sound good.
So like people say, it depends on the key, or the chords that are used in the song. It doesn't necessarily have to be the key the song is in, but whatever key or notes you select for Autotune need to reflect the notes you're singing, or it will try to pull them sharp or flat. I'd agree that chromatic is usually a safe option as long as your pitching isn't more than a semitone out, unless you're going for an hard Autotune effect where it will snap changing tones to notes in a particular scale, rather than a 'chromatic scale'. I can see there's a bit of an art to this when you're rapping and moving between sung and spoken words.
Postby Sam Spoons » Thu Jan 07, 2021 11:47 pm
I think this is right. Going for the hard tuned sound I'd start with the actual notes in the melody and create a custom scale by removing all the notes that aren't in the tune from a chromatic scale. I don't see an issue with a mix of rapping and singing, just defeat the AT plug in during the spoken parts?
Postby CS70 » Fri Jan 08, 2021 12:15 pm
I am currently looking for someplace to crawl under :lol:
Postby zenguitar » Fri Jan 08, 2021 1:05 pm
CS70 wrote:I am currently looking for someplace to crawl under :lol:
How about an Azalea bush?
:angel:
liberté, frivolité et vanité
Next
