Zukan wrote:Sam Spoons wrote:You could add Neumann KH120s at around €570?
That's for a single monitor not a pair.
Yes, I checked prices of a couple on the OPs list, both were priced for single monitors so I quoted the price of the KH120 similarly.
James Perrett wrote:ef37a wrote:I would like to challenge the premise "can't go to a shop and listen to...."
Are/were there eversuch shops where they have a whole stack of speakers readily wired up to some impeccably source and readily switchable for your listening?
I don't know about nowadays but certainly when I bought my first hifi speakers from Guildford Hifi they set up a few different contenders in their demonstration room so that I could compare them. I'm fairly sure they had some kind of custom speaker switch at the time.
Gear4Music has about two dozen sets wired up. It's not a treated room and obviously far from good, but it does show the larger difference between speakers. Certainly enough to knock a few off the short list.ef37a wrote:I would like to challenge the premise "can't go to a shop and listen to...."
Sam Spoons wrote:Zukan wrote:Sam Spoons wrote:You could add Neumann KH120s at around €570?
blinddrew wrote:Gear4Music has about two dozen sets wired up. It's not a treated room and obviously far from good, but it does show the larger difference between speakers. Certainly enough to knock a few off the short list.ef37a wrote:I would like to challenge the premise "can't go to a shop and listen to...."
ef37a wrote:How long to do that with 24 monitor pairs?!!
blinddrew wrote:For the record I wasn't suggesting that the G4M set-up was remotely comparable to a home test, but it answers your question about whether anywhere has stuff set up permanently. And yes, they're all set up through a switcher.
Zukan wrote:Sam Spoons wrote:Zukan wrote:Sam Spoons wrote:You could add Neumann KH120s at around €570?
My bad.
