Best trap arrangement for weird angle
Postby gregims » Tue Mar 02, 2021 8:01 am
Hello, I just finished setting up a new home studio, and I was curious about the best way to set up some bass traps. There at some interaction angles where the wall behind my monitors meets the ceiling. Would I be best to try and get some wedge bass traps for these spots or just use a panel and leave air between the panel and angle to act as the trap. Having some issues attaching a pic, but it’s a narrow ceiling (maybe two feet across) with two walls joining it at >90 degree angles. Thanks!
gregims
Re: Best trap arrangement for weird angle
Postby Mike Stranks » Tue Mar 02, 2021 9:41 am
How to post pics here:
https://youtu.be/s7vVDGTOHW0
Postby Sam Spoons » Tue Mar 02, 2021 11:12 am
I'd guess the length of the signal path through the traps is probably what makes the corner location most efficient but filling the voids can't do any harm. My conclusion, having done my own room with DIY panels and traps, is that the initial, basic stuff is what makes the biggest difference, as long as you don't go mad with thin panels stuck directly on the walls/ceiling anything you do will improve things. Getting bogged down in the minutia uses up time you could have spent playing music.
Postby gregims » Tue Mar 02, 2021 4:46 pm
Let’s see if this works. Pic of the area:
https://m.imgur.com/a/Dud2z7
gregims
Postby gregims » Tue Mar 02, 2021 5:23 pm
Looks like the link worked. I’m also going to panel the sloping walls as well as the wall behind the monitors. It’s possible that will solve a lot of issues, but I was hearing such pronounced boominess that I had to wonder about those angles.
gregims
Postby gregims » Tue Mar 02, 2021 6:13 pm
Sam Spoons wrote:I'd guess the length of the signal path through the traps is probably what makes the corner location most efficient but filling the voids can't do any harm. My conclusion, having done my own room with DIY panels and traps, is that the initial, basic stuff is what makes the biggest difference, as long as you don't go mad with thin panels stuck directly on the walls/ceiling anything you do will improve things. Getting bogged down in the minutia uses up time you could have spent playing music.
Good point. Going to panel the slanting walls and wall behind monitors, and I imagine that will help a lot. (Not going to cover every inch.) Before doing that it’s hard to conclude that the corners are causing the issues I’m hearing.
gregims
Postby Music Wolf » Tue Mar 02, 2021 6:19 pm
gregims wrote:Looks like the link worked.
It's not working for me. Anyone else have any joy?
Music Wolf
Postby Sam Spoons » Tue Mar 02, 2021 6:26 pm
Not for me either, throws up a 404...
Postby Luke W » Tue Mar 02, 2021 6:29 pm
Not working here either.
Gregims, it looks like you've added a hyperlink to the Imgur gallery rather than a direct link to the image itself using the [img] tags.
Luke W
Postby gregims » Tue Mar 02, 2021 6:31 pm
Damn worked for me at first, now a fail.
gregims
Postby gregims » Tue Mar 02, 2021 6:34 pm
https://imgur.com/a/Dud2z7y
Fingers crossed. Thanks for your patience.
gregims
Postby Luke W » Tue Mar 02, 2021 6:37 pm
If in doubt, the link you paste between the tags should always have a picture file extension at the end (.jpeg/.PNG/etc).
It catches a lot of people out, hence Mike making his video!
Luke W
Postby gregims » Tue Mar 02, 2021 6:39 pm
Luke W wrote:If in doubt, the link you paste between the tags should always have a picture file extension at the end (.jpeg/.PNG/etc).
Was mostly surprised that shaking my fist and telling it to get off my lawn didn’t work.
gregims
Postby Music Wolf » Tue Mar 02, 2021 6:58 pm
I'd be inclined to keep it simple with rectangulat traps. One hangind down from the ceiling, a couple running parallel to the sloping walls and one behind your computer screen.
Music Wolf
Postby RichardT » Tue Mar 02, 2021 7:03 pm
Music Wolf wrote:I'd be inclined to keep it simple with rectangulat traps. One hangind down from the ceiling, a couple running parallel to the sloping walls and one behind your computer screen.
Sounds sensible to me. Standard shapes are much easier to work with and more flexible for the future.
RichardT
