Guys,
When air is added (high shelf of 1.5db to 3-4db starting from 7-8kHz or 10kHz) is there a need to add (mid-)low shelf boost as well (1.5 to 2db starting at either 170Hz or 110 Hz) to compensate the change in the highs?
The reason I am asking is coming from the famous “smile” shape (but without the middle cut) and from the hypothesis that if clarity is added at the top it needs to be compensated with small addition of body in the lows to prevent the sound appears “thinner”.
Or I am wrong in my thinking and I’ll make the sound worse?
Compensate added air with (mid-)low boost?
• Page 1 of 1
- george_vel
- Regular
Re: Compensate added air with (mid-)low boost?
I would say, not necessarily! I often add slight HF boosts without adjusting anything else.
- RichardT
- Frequent Poster
george_vel wrote:Guys,
It really depends on the source. Boosting low end with a shelf is seldom a good idea however, unless the sound is artificial and/or controlled and you're sure there's meaningful information there. Down below 40Hz there's seldom anything useful, and most often there's rumble that robs you headroom without contributing much. When it works, it generates wind thru large speakers.
CS70 - Jedi Poster
