Sound Devices MixPre V3.00
Postby Paul Isaacs » Mon Dec 10, 2018 7:09 pm
Many new features and improvements ...
https://www.sounddevices.com/support/do ... /?device=6
Paul Isaacs
Paul Isaacs
Sound Devices LLC
Re: Sound Devices MixPre V3.00
Postby Dan LB » Mon Dec 10, 2018 7:29 pm
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
Dan LB
Postby Bob Bickerton » Mon Dec 10, 2018 7:45 pm
Looks excellent.......
Bob Bickerton
http://www.bickerton.co.nz
Postby Hugh Robjohns » Mon Dec 10, 2018 7:51 pm
With Ambisonic support too. :thumbup: :D
Postby Bob Bickerton » Mon Dec 10, 2018 9:54 pm
Just installed this firmware onto a MixPre-10m and MixPre-3 - all good.
Dug out a Korg Nanocontrol Studio that I wasn't using elsewhere and it works spot-on with the MixPre - this is super cool!
And I happened to have a space in my road case for it.
How about this for the ultimate portable recording solution:
Bob Bickerton
Postby Hugh Robjohns » Mon Dec 10, 2018 10:04 pm
:sick: green with envy... :lol:
Postby Bob Bickerton » Mon Dec 10, 2018 10:43 pm
That's normally my state regarding you!
Bob Bickerton
Postby Dan LB » Mon Dec 10, 2018 10:51 pm
Nice kit Bob! I'm with Hugh on this one :sick: :D
I'm at work right now but will be installing V3.00 onto my MixPre 6 as soon as I get home!
Dan :beamup:
Dan LB
Postby Dan LB » Mon Dec 10, 2018 11:01 pm
Quick question:
As I understand it, there are different types of A-format and B-format (please correct me if I'm wrong), so..... would the new Ambisonics mode allow real-time monitoring of the new RODE NT-SF1?
Dan LB
Postby Hugh Robjohns » Mon Dec 10, 2018 11:45 pm
No, the A-format is a strictly defined arrangement of four sub-cardioid capsules, used by the Sennheiser, rode, soundfield and other ambisonic arrays.
The A-format isnt any use as it is, so is normally converted to the (equally precisely defined) B-format from which it can be further processed to provide a variety of different mono, stereo or surround sound outputs. The B-format can be generated directly (although it is very difficult to do so with height) and some Ambisonic mics (like the higher-end Soundfield's) convert from A- to B-format internally.
Having said that, there are a couple of different arrangements of channel order of B-format signals. Traditionally, it was WXYZ, but there are now formats like AmbiX and FuMa which use WZYX which makes the signal processing easier when used within the higher-order Ambisonic formats.
And to answer your question, yes the new ambisonic plugin for the MixPre allows headphone monitoring of both A-format and B-format signals, with both AmbiX and FuMa formats supported, along with four-channel ganged preamp options etc.
Postby wireman » Tue Dec 11, 2018 12:28 am
Pre-roll now supported on some models, that makes these a lot more interesting to me.
wireman
Postby Dan LB » Tue Dec 11, 2018 2:00 am
Hugh Robjohns wrote:No, the A-format is a strictly defined arrangement of four sub-cardioid capsules, used by the Sennheiser, rode, soundfield and other ambisonic arrays.
Thanks for that Hugh. The whole ambisonics thing is completely new to me and I'm finding some of it confusing. :thumbup:
Dan
EDIT: I've just installed the Ambisonics plugin on my MixPre-6 and have had a quick read of the accompanying manual and things are becoming a lot clearer (and after reading your post Hugh)! Many thanks.
For anyone interested, said manual can be found here: https://store.sounddevices.com/wp-conte ... -UG_en.pdf
Dan LB
