BDS 96K Digital Recorder NOW SHIPPING
Postby tsunami way » Mon Sep 23, 2019 10:41 am
HomeBDS 96K Digital Recorder
Click image to zoom
Share this item
£299.98
BDS company research and development
Standard 1U volume high brightness LCD screen display
Optional USB TF card and hard disk playback or recording storage
Support FAT32 hard disk recording, each song most large record to three Xiaoshi
Supported playback format is AAC.MP3.WAV.APE.FLAC
LCD display supports Chinese song name display
Recording format is optional WAV. or MP3.
Digital interface compatible with 96k input sample rate
WSB adjustable recording 48k or 96k sampling rate
MP3 adjustable recording bit rate 128 192 256 320
Support digital interface and analog interface input and output
Synchronous 0.01 second one-button and two-stage fast recording
Microphone input recording with volume adjustment
Mono to stereo switch button
Recording level indicating band may be adjusted Jog Dial
Support speed control +-24 % function during playback
Automatic recording and digital analog input recording switching
Full-featured folder return and confirmation search button group
Single and continuous play singles and repeat the whole unit
Recording folder quick access function
Headphone output and volume adjustment
Seamless loop AB point
Perfect time display function
90V-260V wide power supply
Technical parameters :
Power requirements: 90V-260V (50HZ / 60HZ)
Power consumption: 15 W - 2 0 W
Signal to noise ratio: 105 dB
Response frequency: 20HZ – 20KHZ
Recording sampling rate: 48KHz , 96KHz
Source output: RCA , XLR , DIGITAL, PHONES
Sound edge input: RCA , XLR , DIGAITAL . MIC
Source specifications: USB , TF
Total harmonic distortion: < 0.01%
Dynamic range: > 98dB
Distortion: > 0.01%
Frequency: 4 8KH z
Dimensions: 483mm * 130 mm * 44 mm
Weight : 3 KG
STORE LINK
http://tsunami-sound-systems.kong365.co ... l-recorder
tsunami way
