BDS Rackmount 2U Spectrum Analyzer Analysis Display Limited Edition was £579.00 £425.00
Postby tsunami way » Mon Sep 23, 2019 10:43 am
BDS Rackmount 2U Spectrum Analyzer Analysis Display Limited Edition NEW RELEASE
Designed by BDS
2U compact rack body sizeHigh quality Main DSP control board
31ch real time frequency level
Integrated 930pcs
LED display module
Each frequency signal with 30pcs led display simple easy to control durable stable
Input and output support XLR and RCA socket
Use high quality Non lossless circuit for output
Panel support dimmer and input signal
Sensitive Real time or smooth time mode
PHT(PEAK HOLD TIME)mode setting
MFT (MAIN FALL TIME) mode setting
Multi display mode setting
Real time stereo input gain level display Auto Gain Control functions
Microphone input with volume
Stereo input spectrum display together
Support AC 90V-260V power
Specifications :
Power supply: AC 90v-260v (50hz / 60hz)
power consumption: 10w - 15w
INPUT SOCKET : XLR, RCA
OUTPUT SOCKET : XLR, RCA
INPUT SENSITIVE: 0v - 1v
LED MODULE : 30*31section
LED COLOR : green ,red
Dimension : 483mm * 88mm * 130mm
Weight : 2.5KG
Short demo clip
https://www.facebook.com/tsunamiway/videos/17434944
STORE LINK
http://tsunami-sound-systems.kong365.co ... ed-edition
tsunami way
