60% off Zynaptiq Intensity + free Zero-G sample library worth £42!
Postby TimeSpace » Tue Oct 15, 2019 11:03 am
With just one control, Zynaptiq Intensity can add immense clarity and body to your mixes that can normally only be achieved with many plug-ins chained together!
Process individual tracks like speech, SFX, instruments – including guitars, bass and piano – as well as full mixes, multi-channel film stems, drum busses, and other complex content. It's an indispensable tool for music producers, mastering engineers, sound designers and more!
"Adds space and detail to a mix in a quite dramatic way but without the end result sounding processed. Bias control can be used to fine-tune a mix’s tonal balance without relying on conventional EQ. Very easy to use" - Paul White, Sound on Sound
DEAL!
Buy Zynaptiq Intensity from Time+Space and not only will you save 60% we'll also send you Zero-G's Elektrolytic sample pack by Ian Boddy for free (worth £42)! And don't forget, you'll earn Loyalty Points worth over £5 too
Just add both items to your cart and Elektrolytic will appear as free when you checkout.
Check out Intensity here: https://www.timespace.com/products/zynaptiq-intensity
TimeSpace
Time+Space Ltd
