Behringer Wing
Re: Behringer Wing
Postby Eddy Deegan » Wed Dec 04, 2019 11:46 am
Behringer just put up a short video answering some questions about the Wing for those interested: https://www.youtube.com/watch?v=cyANIOZXtlo
Some of my works.
Re: Behringer Wing
Postby Folderol » Wed Dec 04, 2019 2:37 pm
Impressive. They really are paying attention to the users aren't they.
Yes. I am that Linux nut.
Re: Behringer Wing
Postby Burakpro » Tue Feb 04, 2020 3:36 pm
I was planning to buy Wing, but unfortunately Stage box doesn't have Midas pre-amp, therefore sound quality will be different. What do you guys think? Am i right? When behringer will release new stage box with midas preamps then i will purchase Wing with Stage boxes.
What is your opinions in that?
Regards
Burakpro
Re: Behringer Wing
Postby DGL. » Tue Feb 04, 2020 4:37 pm
Burakpro wrote:I was planning to buy Wing, but unfortunately Stage box doesn't have Midas pre-amp, therefore sound quality will be different. What do you guys think? Am i right? When behringer will release new stage box with midas preamps then i will purchase Wing with Stage boxes.
Regards
The stagebox to use with the Wing if you want the Midas pro preamps are the DL16/32, the ones originally designed to complement the M32. They are Midas versions of the Behringer S16/32.
https://www.thomann.de/gb/midas_dl16.htm
https://www.thomann.de/gb/midas_dl_32.htm
I believe 48k compatible pro series boxed i.e. DL151 work as well.
DGL.
Re: Behringer Wing
Postby Sam Spoons » Tue Feb 04, 2020 4:50 pm
Yup, as DGL says the Midas versions of the stage box are available. And they have been around for a few years too.
Re: Behringer Wing
Postby DGL. » Tue Mar 31, 2020 4:26 pm
New FW update,
https://www.youtube.com/watch?v=b0RSEZdAqh4
https://www.youtube.com/redirect?q=http ... escription
Firmware 1.06 New Features
• Metering on all routing pages indicate raw input signals
• Bus to bus mixing (all buses can send into buses 1..8)
• Delay for main buses
• Pre/post selection for bus to bus and bus/main to matrix sends
• FX parameters can now be assigned to faders
• Dynamic EQ for the gate plugin slot
• Compressor 'all' switch (gui) for 76 limiter amp
• GPIO control can be assigned to custom control buttons directly
• Talkback can be controlled by custom controls (and GPIO)
• RTA metering on GEQ FX
• Console lock function holding the HOME button depressed
• Source assignment/mode switch and phantom control on channel HOME page
• Channel delay moved to post fader
• Improved customization copy during source assignment (drag)
• USB player with song list, re-ordering and repeat functions
• Up to 4-ch USB play and record at the same time (with fast usb drives)
• USB transport buttons in custom control section
• New routing page to assign sources to channels
• Firmware update from usb drive via setup menu
New Features
• Increased usb drive compatibility
• Random sends on fader bug fixed (faders not moving)
• Increased stability of the usb player/recorder
• General gui/workflow bugfixes and enhancements
DGL.
Re: Behringer Wing
Postby OneWorld » Tue Mar 31, 2020 4:56 pm
This is looking better and better all the while. There was a demo model sold on eBay the other week £2245.00 - very tempting
One thing I am not clear about, with the 64 record, and 64 playback, could it be considered to be a multi-track recorder - seems to good to be true. Or is it like the A&H Qu-series, or the Durec on RMS UFX, you can either record stereo or all the channels but nothing in between (ok you could record n-channels but not play them back and record on another channel, as you would with a multi-track recorder
OneWorld
