APD Offer: 67% Off SEQUI2R EX by Audiofier!
Postby Audio Plugin Deals » Tue Jan 21, 2020 2:01 pm
SEQUI2R EX IS AUDIOFIER’S FLAGSHIP UNIQUE STEP SEQUENCER WITH AN ENORMOUS LIBRARY OF SOUNDS, FOR NI KONTAKT (Not compatible with NI Kontakt Player)
For only $39.99 instead of $119.99 (67% OFF), get SEQui2R EX – the all new cutting edge step sequencer by Audiofier!
SEQui2R EX is more than a step sequencer, a gater, an arpeggiator or a pulse engine. With SEQui2R You are in control. You choose the notes that suit your composition and SEQui2R will do the rest. SEQui2R features two separated sound engines, 8 distinct phrases recorders, with independent step panner, step volume, 2 step filters, step distortion and a step lo-fi per engine.
With SEQui2R’s CUSTOM KEY MANAGER you can play in your desired key using the correct intervals. You can even make up your own scale. Save it, export it and import it in other projects!
This is a limited time offer you do not want to miss, hurry and save!
Offer Page:https://audioplugin.deals/sequi2r-by-audiofier/
Offer Expires: February 3rd
https://soundcloud.com/user-688579952/s ... -audiofier
https://www.youtube.com/playlist?list=P ... Zk-BnA_X7d
Audio Plugin Deals
