ModeAudio releases 'Vintage Drum Loops' & 'Collage - Serum Electronic Presets'
Postby ModeAudio » Tue Feb 18, 2020 4:17 pm
ModeAudio has released two new, royalty-free packs, Vintage Drum Loops & Collage - Serum Electronic Presets.
Vintage Drum Loops is a mini-pack containing 50 grooves that conjure up Hip Hop's heyday - ranging from the bass-heavy punch of Boom and Bap to the tight, bright sound of 80s Funk. Also included are 60 drum samples, sliced from the main loop selection, and each of the 50 breaks is also presented as a MIDI pattern.
Pack Details:
- 50 Drum Loops.
- 60 Drum Samples (Kicks, Snares, Claps & Hi Hats).
- 50 MIDI Loops (Key & Tempo-Labelled).
- 100% Royalty Free.
Check out the pack!
Collage - Serum Electronic Presets contains 50 patches spanning chunky, analog-style basses, haunting pads, cascading synth leads, drifting arps, spiralling SFX and driving percussive sequences. Also included in the pack are 39 custom-sampled wavetables, 19 drum machine loops and 56 key and tempo-labelled MIDI files across the EDM, Pop and Electronica genres.
Pack Details:
- 50 .fxp Presets (Arps, Basses, Pads, Synth Leads, Percussion Sequences & SFX).
- 39 Custom Wavetables (Synths, Guitars, Kicks & Percussion).
- 19 WAV Drum Loops.
- 56 MIDI Files (Key and Tempo-Labelled).
Check out the presets!
ModeAudio
Loops | Samples | Synth Presets
modeaudio.com
