Turn Your Sample Packs into Virtual Instruments with this New Sample Player
Postby replikasound » Thu Apr 02, 2020 8:58 am
Hi All..
Replika Sound have just released AUDITION PLAYER for Kontakt5.3+. This is a brand new Sample Player Engine that allows you to load you own Samples.
AUDITION PLAYER
Audition loads your Samples and spreads them out 1 Sample per Key. Simply select one of your Samples with your MIDI keyboard and click a button on the GUI to have that Sample spread out across 6 Octaves.
Layer 4 Samples together.
Each Sample Layer has its own controls for :
Volume, Pan, Stereo Width, Pitch, HP and LP Filters, Chorus, Tube Drive, Delay, long evolving LFO Sweep FX, Tempo-Synced Pulse (Stutter) and Filter Gates, Tempo-synced AutoPan and ADSR envelopes.
There are Master Filters, Envelopes and Effects like Delay and Reverb.
Audition is like a bridge between static Sample Packs and fluid playable Virtual Instruments.
Chamaeleon Pads & Drones uses the same Sample selection Engines as Audition and is bundled free with Audition.
Chamaeleon Pads & Drones comes with 123 Fat Analogue 24-bit 6-Octave Multi-Sampled Pad Sounds and 101 Presets. Combing these Samples with the Audition Engine can make literally millions of sound combinations.
There is a FREE Demo version of Both Audition and Chameleon. There are some limitations which are listed in the README file in the demo pack.
MSRP: £32. On Sale for ONLY £5 until 16th April 2020
Thanks,
Roo
replikasound
Composer. Sound Designer. Audio Mixer. Virtual Instrument Designer
