Cohler Classical 2.012 - Source Destination Editing
PostPosted: Tue Jun 02, 2020 3:08 am
by cohler
With 2.012, we've made some great enhancements to Cohler Classical!
Thank you to everyone for all the great feedback. With the user base growing rapidly all over the world, it is really exciting! We are adding new features all the time, and sticking to our immediate customer service and no bugs allowed policy.
Our users really span the gamut from well-known performing musicians, to independent studio engineers, record companies, major studios, and concert halls; and they hail from five continents in cities as far flung as San Francisco, New York, Boston, London, Berlin, Amsterdam, Christchurch (New Zealand), North Sydney (Australia), Cisternino (Italy), and Laguna de Duero (Spain) to name just a few...
Here's a short list of some of the great new features, many of which came from your suggestions:
  • New recording templates for Duo with piano, String Quartet, Piano Trio, Chorus, Oratorio, Chamber Orchestra, Mozart Symphony 35, and more!
  • Auto error checking/correction for incorrect item moves or deletion
  • Automatic large/resizable take number window, which can also be toggled visible/invisible. You can even drag this over to a separate monitor in a studio setting so everyone can easily see it!
  • Take number window is tied to project, so if you click between project tabs, it auto updates according to the load directory associated with each project
  • One-click record arm that guarantees consistency between your project and your load directory
  • A new notification at startup to let you know that the Cohler Classical background process is running
  • New File => Delete items and files... command
  • Even more speed enhancements
  • Options => Update setup => Copy mixer settings to sources now copies everything in the mixer including the track playback time offset, which by the way, is a great and simple way to do delays for spot mics for the distance between spot and main mics (0.888 ms per foot, FYI).
  • Four New videos!
  • And lots more...
Keep the feedback coming. And as always, if you need help with anything, we are happy to meet you on Zoom any time to solve your problems immediately.
_________________________________________________
Available NOW for PC & Mac • FREE Trial License included
info@cohlerclassical.comhttps://cohlerclassical.com
Release 2.013: New videos, Metadata, Auto fade-in-out, Close gap, Left shift and more!
PostPosted: Tue Jun 09, 2020 12:45 am
by cohler
Cohler Classical 2.013 is out and live on the newly updated website!
In addition to bug fixes, and speed enhancements, here are just some of the new features in this release:
  • WAV Metadata functions are all updated and organized under one menu: Options => (Metadata) WAV:
    • Set...
    • Get
    • Update...
    • File info
  • The new Metadata video explains everything
  • The new Play/Record => Playback => Play-stop with fades command allows you to do auto fade-in and out on play and stop respectively. This feature is perfect for anyone doing podcasts, live broadcasts, instructional videos, and the like, and
  • You can set the fade-in and out parameters at Options => Play-stop fades...
  • The new Play-stop with fades video explains all
  • Three new functions have been added under the Edit menu for closing gaps between items and left-shifting items. Just put the edit cursor anywhere in a gap (or at either edge) and execute the "Close gap" command with or without crossfade.
    • Edit => Delete => Close gap, crossfade
    • Edit => Delete => Left shift
  • Updated website with direct links in text to associated videos!
  • And more...
Enjoy!
Please email me your suggestions and questions. And if you need help with something, let me know when you are available to meet on Zoom, and I will be more than happy to answer your questions and get you going in short order.
Note: Due to the large number of users on five continents now, I do not have the time to answer complex questions in email, and doing so is much more time consuming and complicated than necessary. So if you have such a question or problem, email with your time availability to meet on Zoom and we can solve your problem quickly and directly.
_________________
Jonathan Cohler
Source-Destination 4-Point Editing for REAPER!
Cohler Classical Release 2.014! What Customers are Saying; New features; New videos!
PostPosted: Wed Jun 17, 2020 9:16 pm
by cohler
Cohler Classical 2.014 is out and there's a newly updated home page which includes What Customers are Saying!
IMPORTANT: The people at Cockos graciously fixed the major bug they introduced in 6.11 and that we reported, so you can install 6.12c or you can continue with 6.10 or earlier versions, but DO NOT USE REAPER 6.11 with Cohler Classical.
Cohler Classical 2.014 features more and more speed enhancements and features!
  • NEW Licensing video
  • NEW drag lock feature (Options => Drag lock) to prevent accidental item drags
  • NEW 2x fade audition (Play/Record => Around fade 2x)
  • NEW command to renormalize volume envelopes based on level of first point in each envelope, and then reset overall trim for the track so that total volume is unchanged. (Automation => (ALL TRACKS) Renormalize read-trim)
  • New keystroke assignments:
    • File => Open related projects => Open projects from list - ⇧⌘O (Shift-Control-O on Windows)
    • File => Open related projects => Save list of open projects - ⇧⌘S (Shift-Control-S on Windows)
    • File => Close all projects - ⇧⌘F4 (Shift-Control-F4 on Windows)
  • Updated website pages:
  • Updated installation software includes automatic email confirmation messages now so we can make sure that our messages are getting through to you and vice versa!
  • Bug fixes
  • And more...
Enjoy!
