New : Bass Synth for Kontakt 5 with Intro Offer
Postby replikasound » Thu Jun 04, 2020 7:29 am
Hi All..
Replika Sound have just released AUDITION PLAYER with VOLTUS BASS SYNTH for Kontakt 5.3+. AUDITION is a Sample Player Engine that allows you to load your own Samples and is bundled here with a massive Bass Synth.
Audition loads your Samples and spreads them out 1 Sample per Key. Simply select one of your Samples with your MIDI keyboard and click a button on the GUI to have that Sample spread out across 6 Octaves.
Layer 4 Samples together.
Each Sample Layer has its own controls for :
Volume, Pan, Stereo Width, Pitch, HP and LP Filters, Chorus, Tube Drive, Delay, long evolving LFO Sweep FX, Tempo-Synced Pulse (Stutter) and Filter Gates, Tempo-synced AutoPan and ADSR envelopes.
There are Master Filters, Envelopes and Effects like Delay and Reverb.
Audition is like a bridge between static Sample Packs and fluid playable Virtual Instruments.
VOLTUS BASS uses the same Sample selection Engines as Audition and is bundled free with Audition.
Voltus Bass comes with 125 24-bit 5 Octave Multi-Sampled Bass source sounds and 200 Presets.
Combining these Bass Sounds with the 4-layer Audition engine can make literally millions of sound combinations. Voltus is capable of a wide variety of Bass textures - gritty aggressive dark bass, warm deep rolling sub, long evolving bass pads or organic braam-like brassy low registers.
There is a FREE Tryout version of Both Audition and Voltus. There are some limitations which are listed in the README file in the demo pack.
MSRP: £32. On Sale for ONLY £5 until 14th June 2020
Thanks,
Roo
replikasound
Composer. Sound Designer. Audio Mixer. Virtual Instrument Designer
