APD Offer: 60% Off CABAL 8 by Wavelet Audio
Postby Audio Plugin Deals » Mon Jul 06, 2020 9:56 am
For only $64.99 (instead of $159), get CABAL 8 – a new breed of guitar sampling by Wavelet Audio!
Weighing in at 15.9 GB, CABAL 8 brings 8-string power to your music. CABAL 8 features tons of fresh and unique possibilities.
Cabal 8 enables you to create powerful and natural eight-string guitar parts that imitate actual guitar playing! Cabal 8 guitar is suitable for work in various styles. Don’t limit yourself with only hard music genres.
Note: Requires the FULL version of Kontakt 5.7.3 or higher
Deal page: https://audioplugin.deals/deal-2
Deal ends on July 19th, 2020
KEY FEATURES
  • The unique algorithm of the portamento slide. You can control all aspects of portamento: speed, starting and ending positions, what noises will be present.
  • The possibility to disable certain strings from the instrument. CABAL 8 will automatically reallocate the load to the remaining strings, if possible.
  • The possibility to tune each of the strings. That allows you to customise the instrument to any desired guitar tuning.
  • Possibility of detailed equalisation. You can equalise the whole instrument or even a specific articulation of a separately selected string.
  • Keyswitch Mode, in which you can flexibly adjust the string selection for each note using velocity.
  • The possibility to configure articulations routing map, sending them to certain buses.
TECHNICAL SPECIFICATIONS
  • Over 13500 hand-edited samples in 48 kHz / 24-bit.
  • 6 primary articulations (Sustain, Palm Mute, Short Palm Mute, Harmonics, X-Note, Tappings) and 2 additional articulations (FX Sustain, FX Palm mute)
  • Up / down picking
  • 8 Round Robins per note
  • 3 guitars: DI Clean, Hi-Gain, Crunch
  • MIDI included
  • Requires the FULL version of Kontakt 5.7.3 or higher
  • 8.52 GB of hard drive space (15.9 GB of original sample material).
https://www.youtube.com/playlist?list=PLRQNjyldNemzitW6ct2fkxoTj1J8JZ5pC
https://soundcloud.com/wavelet-audio/sets/cabal-8-demos
Audio Plugin Deals
