Loop-Based Riser Designer and Ping Designer with Audition Player for Kontakt 5 with Intro Offer
Postby replikasound » Tue Jul 07, 2020 8:38 am
Hi All..
Replika Sound have just released MURALIS RISE & PING with AUDITION PLAYER for Kontakt 5.3+.
Muralis comprises 2 Instruments - A Loop-based Riser Designer and a Ping / Signature Sound Designer.
RISE - Easily design unique Risers by layering up to 4 Samples from 88 sound sources. Because the sounds are loop-based you can have a Riser for ANY Length, at ANY Tempo and from ANY Pitch to any other.
The Pitch Bend Range has a max of +/- 24 semi-tones (making a full range of up to 48 semi-tones).
PING - Choose up to 4 layers of sound from 99 source sounds and 31 Reverb Impulse Responses.
Both RISE and PING use the same AUDITION Kontakt Engine and work in the same way. Each comes with 25 presets.
Each Sample Layer has its own controls for :
    Tempo-synced Volume (Stutter) Gate (Rates from 1/16th to 4 beats - triplet options as well)
    Tempo-synced LP Filter Gate
    Tempo-synced AutoPan
    ADSR Envelopes
    Volume, Pan, Stereo Width, Pitch, HP and LP Filters, Chorus, Tube Drive, Delay
    Long Evolving multi-LFO Sweep FX
There are Master Tempo-synced Volume and LP Filter Gates, Filters, Envelopes and Effects like Tempo-synced Delay, Distortion and Convolution Reverb
All the features are fully MIDI automatable. All Instruments respond to MIDI CC11.
AUDITION is a Sample Player Engine that allows you to load your own Samples. It comes bundled free with Muralis Rise & Ping. Loaded Samples are spread out across your MIDI keyboard 1 Sample per Key.
Simply select one Sample with your MIDI keyboard and click a button on the GUI to have that Sample spread out across 6 Octaves.
Layer up to 4 Samples together.
Audition is like a bridge between static Sample Packs and fluid playable Virtual Instruments.
MSRP: £32. On Sale for ONLY £10 until 16th July 2020
Thanks,
Roo
replikasound
Composer. Sound Designer. Audio Mixer. Virtual Instrument Designer
