APD Offer: 44% Of SampleX, the Vintage Sampler Emulator by BeatSkillz
Postby Audio Plugin Deals » Mon Jul 13, 2020 9:14 am
​For only $39 instead of $69, get SampleX – the vintage sampler emulator by BEATSKILLZ!
SampleX brings you accurately modeled vintage sampler emulation. Dial-in the sample rate, bit rate, aliasing, input drive and filter settings to sound like any sampler, or design your own! Multiple sampler emulation presets already included.
The Sample Rate Interpolation system built in DSP lets you dial in any sample rate from 96 kHz to 2 kHz. You can also “type” in the values.
Deal page: https://audioplugin.deals/samplex-the-vintage-sampler-emulator-by-beatskillz/
Deal ends on July 26th, 2020
Key Features
  • Emulate any Vintage sampler by using the key controls which actually shape the sound of those units
  • Create the true desired aliasing without changing the pitch of a sample with the Shift control
  • Accurately modelled Input Drive of the s900, a major part of the vintage sampler sound being sought.
  • An accurate model of the famous Ladder Filter with resonance!
  • Dial-in any sample rate from 96khz down to 2 kHz, reduce bit rate up to 4 bits
  • Blend in the dry sound and have total control on the amount of “effect”
  • “Type” in the values for more accurate control and sound shaping
  • Multiple carefully “ear” matched vintage sampler emulation models included in the presets
VIDEOS
https://www.youtube.com/playlist?list=PLq5zvy3wsKYZT9fVbPB1Zpg8EnwZStiwo
Audio Plugin Deals
