Eventide's Blackhole Reverb pedal is here!
Postby Orville71 » Tue Sep 15, 2020 5:07 pm
Hi everybody, in case you haven’t heard, I’m pleased to announce the release of the Eventide Blackhole reverb pedal!
Learn more about the pedal here:
https://www.eventideaudio.com/blackhole-pedal
Blackhole demonstration videos can be viewed at https://etide.io/blackhole-pedal-videos
Features
Five presets loaded at your feet with dozens more available with Eventide Device Manager (EDM) software
Control the Size of your space from a cartoonishly small room to a limitless universe
Use PreDelay to offset the onset of the reverb
Turn up Feedback to go beyond the event horizon
Tap the Freeze Footswitch to instantly 'freeze' your sound
Dual action Active Footswitch is latching or momentary
Rear panel Guitar/Line Level switch for selecting use with guitar, synths, FX loop or DAW interface
Map any combination of parameters to an Expression Pedal
Use a single Aux switch to Tap Tempo or a triple Aux switch for easy preset changing (up/down/load)
MIDI capability over TRS (use with a MIDI to TRS cable or converter box) or USB
Multiple Bypass options: Buffered, Relay, DSP+FX or Kill dry
Catch-up mode helps dial in your sound when toggling between presets/parameters
Eventide Device Manager PC or Mac application for software updates, system settings and creating/saving presets
Fine-tune your tone with Lo, Hi and Q (resonance) controls. Use the tone controls to add airiness or clear up the low-end. Map the EQ controls to an expression pedal to add movement to the reverb tail
Unique Gravity control to custom-tailor the reverb tail in two realms — normal or inverse decay. Create interesting swells or suck the dry signal back into the reverb tail. At longer decay times, Blackhole allows the articulation to shine through without competing with the reverb tail
Discover what lies beyond mere halls, rooms, plates and springs; Eventide’s Blackhole pedal transports tone to an alternate dimension of ambience. Blackhole is available for $279 (MSRP) from Eventide dealers worldwide and at https://eventideaudio.com/blackhole-pedal
Orville71
