APD Offer: 49% Off Cue Builders Cinematic Rhythms by Red Room Audio
Postby Audio Plugin Deals » Thu Sep 17, 2020 7:53 am
For just $49.99 (instead of $99), get Cue Builders Cinematic Rhythms by Red Room Audio.
Cue Builders Cinematic Rhythms provides a fast and flexible way to add dramatic epic and world percussion to your music.
Cue Builders Cinematic Rhythms comes with over 400 deep percussion phrases/loops, each with up to 6 mixable stems organized by tonal color. 19,000+ samples available in 16 or 24-bit, plus an 8-slot FX rack.
Originally $99, now available for just $49.99 for a limited time only! This is an amazing offer you should not miss.
Promo page: https://audioplugin.deals/deal-1
Promo ends on September 30, 2020.
Key Features:
  • NI Kontakt (full), version 5.8.1 or above.
  • 16 GB (16-bit) or 25 GB (24-bit) disk space.
  • 2 GB RAM (4 GB recommended).
  • 2008 or later processor.
  • Your system must also meet the requirements for version 5.8.1 of Kontakt. If you cannot run that version, you will not be able to load this library.
  • Over 400 multi-stem epic and world percussion loops recorded on a scoring stage.
  • Loops contains up to 6 mixable stems organized by tonal color.
  • 6 time signatures (3/4, 4/4, 5/4, 6/8, 7/8, 12/8).
  • Sampled at 4 speeds for realistic tempo-syncing.
  • 2 microphone positions (Close and Hall).
  • Modern, easy to use, feature-packed GUI.
  • Playable end hit samples.
  • 8-slot FX rack.
  • Drag and drop .wav files included.
  • Watermarked for copy protection.
  • 19,120 samples (16-bit or 24-bit/44.1 kHz .wav).
VIDEOS
https://www.youtube.com/playlist?list=PLq5zvy3wsKYYM1ddBunjQMqzsz4D8m1lu
AUDIO DEMOS
https://soundcloud.com/red-room-audio/sets/cue-builders-cinematic-rhythms
Audio Plugin Deals
