64% Off Vibe Drums Bundle by MusicalSampling
Postby Audio Plugin Deals » Thu Oct 01, 2020 10:30 am
For just $99.99 (instead of $277), get the Vibe Drums Bundle by MusicalSampling!
The Vibe Drums Bundle includes a total of 24 unique mix presets and 22 GB of content that cater to a plethora of music styles, from 60’s Rock and Metal to Indie and RnB.
All mix presets were carefully developed and mixed from scratch using an arsenal of processing tools, both hardware and software. This allowed the MusicalSampling team to dial in the precise mix and vibe we were looking for without being limited to Kontakt’s range of processing plugins. The result is a collection of interchangeable mixes that instantly work for a variety of genres with little to no post-production.
Just select your preferred global mix preset, interchange them where necessary and get back to finishing your track.
Originally $277, Vibe Drums Bundle is now available for just $99.99 for a limited time only – you save $177! This is an amazing no-brainer offer you should not miss!
Deal page: https://audioplugin.deals/deal-1
Deal ends on October 14th, 2020
KEY FEATURES
  • 22 GB of content (compressed NCW format)
  • 37,000 samples
  • 24 unique global mix presets
  • Interchangeable mix presets per drum group
  • Simple and intuitive interface
  • Live hi-hat grooves that sync to your DAW’s tempo
  • Crossfadeable hi-hat grooves (fades between various closed/open hi-hat states)
  • Groove Speed control (Half/Normal/Double)
  • Adjustable Humanization feature (Off/Tight/Natural/Loose)
  • Assignable Kontakt outputs for each drum group
  • All presets carefully mixed and “baked-in” outside of Kontakt
  • Recorded in 48khz/24bit
  • Performed by Brian Scoggin (Casting Crowns)
  • Requires full retail version of Kontakt 5.8.1 or higher
  • Free Kontakt Player NOT supported
  • Receive watermarked product by Continuata Connect downloader
VIDEOS
https://www.youtube.com/playlist?list=PL-B8XF-Z9rbHu_bHzqlZpA0C8-jVYSN-n
AUDIO DEMOS
https://soundcloud.com/user-688579952/sets/vibe-drums-bundle
Audio Plugin Deals
