APD OFFER: 68% Off Spectrum 2 (VST, AAX, AU) by Schulz Audio
Postby Audio Plugin Deals » Fri Apr 23, 2021 7:26 am
For only $19 (instead of $59), get Spectrum 2, an incredibly versatile and simple to use spectrum analyzer plugin by Schulz Audio!
Spectrum 2 allows you to inspect the frequency content of your mixes. Spectrum 2 is ideal for finding and cleaning up clashing frequencies in your mix. It supports input from multiple channels: just drop an instance at each point in the signal chain you want to measure.
Spectrum 2 is available as a VST/AU/AAX plugin, as well as a standalone application for Windows and Mac.
Deal page: https://audioplugin.deals/spectrum-2-by-schulz-audio/
Deal expires on May 6th, 2021
KEY FEATURES
  • Super fast graphics
  • Zero routing
  • User selectable colours
  • Instance renaming
  • Spectrogram & spectrograph display modes
  • Variable block size: 2k-16k
  • Variable refresh rate: 40ms – 200ms
  • Spectral smoothing: zero to eight seven
  • Manual & auto-ranging
  • Display Frequencies in Hz and as musical Note
  • VST2, VST3, AU, AAX, App
  • 32 & 64 bit / Windows & macOS supported
VIDEO
https://www.youtube.com/watch?v=Rm-o2Hx0Bak
Audio Plugin Deals
