APD Offer: 50% Off NoteMatrix 2 by HD Instruments
Postby Audio Plugin Deals » Tue May 04, 2021 10:31 am
For only $14.99 (instead of $30), get NoteMatrix 2 by HD Instruments!
NoteMatrix 2 is an elegant and sophisticated MIDI mapper for Kontakt/Kontakt player (Ver 5.8 and above) that grabs incoming MIDI notes from your MIDI hardware, and swaps them in real-time with other MIDI notes and channels of your choice. The configuration is then saved with the track so you won’t have to map it ever again!
By simplifying the integration, NoteMatrix 2 breaths new life into your Controller and Samples!
Originally $30, NoteMatrix 2 now available for only $14.99! This is an amazing offer you should not miss!
Deal page: https://audioplugin.deals/notematrix-2-by-hd-instruments/
Deal ends on May 17th, 2021 at midnight eastern time
KEY FEATURES
  • Get instant access to your favorite sounds, mapped, as soon as you select a track in your DAW!
  • Easy recallable MIDI mapping matches your hardware and software quickly and painlessly.
  • Break free from external MIDI editors/Drum maps/preset flipping.
  • Eliminate the need to reprogram your MIDI hardware physically.
  • Adjust the velocity response of each pad using the Fixed/Shift velocity sliders.
  • Big clear MIDI monitor that tracks your MIDI data.
  • Play melodic instruments on your Pad/Drum Controller using the Length Knob.
  • Works with BOTH the full version of Kontakt (5.8.1+) AND the free Kontakt Player.
VIDEOS
https://www.youtube.com/watch?v=AJp-dW8 ... LAgHSAhG7j
Audio Plugin Deals
