ModeAudio releases 'Aerial - Downtempo Piano Loops'
Postby ModeAudio » Fri May 07, 2021 10:04 am
ImageModeAudio has released Aerial - Downtempo Piano Loops, a 491MB set of royalty-free loops, samples and MIDI spanning piano figures, Ambient textures, instrumental riffs and organic drum rhythms.
155 music loops form the backbone of the pack - comprising sonorous piano chords and airy, lilting melodies, orchestral string parts, gentle tuned percussion and drum patterns that combine drum machines with found sounds and foley.
Also included are 73 tail samples, designed to be paired with the loop of the same name, and 75 key and tempo-labelled MIDI loops, which give access to all of the melodic, harmonic and rhythmic content heard in the main loops folder.
Pack Details:
- 44 Ambience Loops
- 37 Drum Loops (Kicks, Top Drums & Full Beats)
- 19 Instrumental Loops (Strings, Tuned Percussion & Mellotron)
- 43 Piano Loops
- 12 Texture Loops
- 303 Files In Total
Check out the pack!
ModeAudio
Loops | Samples | Synth Presets
modeaudio.com
