APD Offer: 60% Off PREPARATO Piano by Xperimenta Project
Postby Audio Plugin Deals » Thu May 13, 2021 9:53 am
For only $59.99 (instead of $248), get PREPARATO Piano by Xperimenta Project.
PREPARATO Piano, the first instrument of the PREPARATO series, is an inspiring library for Kontakt made from the combination of the incredible characters of a Prepared Piano, in a hybrid modular software.
PREPARATO is not just a prepared piano library recorded with 15 incredible techniques; thanks to the “Acoustic Modular Instrument” engine based on a multi-layering system, PREPARATO allows you to have incredible control over the acoustic source, with endless possibilities of combination.
Limited time offer, don’t miss out
Deal page: https://audioplugin.deals/deal-1
Deal ends on May 26th, 2021 at midnight eastern standard time
KEY FEATURES
  • 6008 Samples, 7,51GB
  • +200 Presets made by sound designer and professional artists
  • 15 Unique Piano Techniques, recorded in a beautiful church with top-end gear
  • Endless possibilities: the ACOUSTIC MODULAR Engine allows you to set up to 5 techniques at the same time, with a layer system
  • Preset Manager, with more than +150 Factory Presets made by professional sound designers
  • Advanced Layer Settings: each layer has an independent Filter, Envelope, Distortion, Formant Control, and LFO.
  • The “Key SET” feature allows you to assign a different technique for each key
  • 2 Convolution Reverbs: “Real Spaces” and “Special Effects” with more than 50+ IR
  • A powerful internal arpeggiator with a simple-to-use graphic interface.
  • “Humanize” allows you to make your instrument alive and creative
  • CC Support with functions such as “Volume Range”, for total control through MIDI
  • “Random Size” allows you to have a simulated Round Robin up to 12 cycles
  • Requires Kontakt Full 5.5 or higher
VIDEOS
https://www.youtube.com/playlist?list=PLq5zvy3wsKYZfrS3OIn99DSKAYxM23hkN
SOUNDCLOUD DEMOS
https://soundcloud.com/xperimenta-sounds/sets/preparato-piano-xperimenta-project
Audio Plugin Deals
